Mon, Jan 20, 5:43 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 19 10:19 am)
Subject: Poser 11 vs Poser 12?
3dkaya ( ) posted Thu, 10 June 2021 at 10:42 AM · edited Sun, 19 January 2025 at 11:41 AM
I have been out of the loop with 3D stuff for a year or so since my laptop died. The latest version I have is Poser 11 (assuming I can still download it as I lost the email address I registered it to) What makes Poser 12 better than Poset 11? I might be getting some money soon as in not sure when but soon hopefully so I can buy a new laptop. I'm debating if I have enough $$$$ I could upgrade to 12. Also where can I find the minimum requirements for either version of Poser?
RedPhantom ( ) posted Thu, 10 June 2021 at 12:28 PM
Site Admin
the system requirements for 12 are at the bottom of the page here
CobraBlade ( ) posted Thu, 10 June 2021 at 10:29 PM · edited Thu, 10 June 2021 at 10:29 PM
If you mainly use Firefly you can happily continue using Poser 11 without it being an issue. If you render using Superfly however, the cost is worth the time you'll save on your renders alone. Especially if we are talking CPU rendering.
Poser scripts by Snarlygribbly
seachnasaigh ( ) posted Fri, 11 June 2021 at 11:35 AM
P12's adaptive sampling with threshold [___] can let you use high quality settings in Superfly without a huge render time penalty. If P12 Superfly sees that a given pixel has not changed after X number of samples, it considers that pixel to be finalized, and skips it on later samples. At the beginning of a render, progress will be as slow as P11's Superfly, but after a lot of pixels have been finalized, P12 Superfly only spends its time on the tough areas of your render, and you see the rate of progress increase significantly.
These are the settings I used for the Grey Havens test/promo renders:
Caveat: If your PC is Win7, it is not officially supported in P12. I'm on Win7, and so far P12 works (except the embedded store). My GPU is an old Quadro, so I'm limited to CPU-only rendering. You would need Win10 to make full use of RTX3090 GPU rendering power. P11 can't fully exploit the RTX series GPUs, and Win7 can't either.
Y-Phil ( ) posted Fri, 11 June 2021 at 2:28 PM
Another point on which I save a significant amount of time: I have a rather common setup for the skins, and changing only the bitmaps using a single drag-and-drop is a real winner for me.
It is as simple as:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
