Poser 12 F.A.Q (Last Updated: 2024 Sep 30 4:44 pm)
Is it a transmap and texture and you're going to use it in Materials Room eyebrows? Or as a P12 layer? Or is it an object? (Just curious. I likely don't have an answer for you.)
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
Good luck. I'm sure someone here can help you with that eventually. To me, it sounds like a prop that needs to be parented to the head, but I'm not skilled in rigging.
Old lady hobbyist.
I think you'll have to rig it as a head and then add the movement morphs. As far as the face handles, that's beyond me.
Are they modeled so that they fit where they should on the figure, if so, possibly load the obj into poser, then use la femme as the donor rig in the setup room.
Consider me insane if you wish, but is your reality any better?
RedPhantom posted at 1:17PM Sat, 26 June 2021 - #4422079
Tried that. You see you have to go into the fitting room and port the morphs over and then in the pose room copy the joint from la femme. And then you can conform. But somehow it doesn't seem to work. I have sent nerd a dm hopefully he can help.
You'll also have to set up groups in the brows, which could be a major PITA. In fact just one of a list of PITAs in regard to working with La Femme and her expression chips. Everything becomes a JCM. It's helpful to bring some python tools into play... but it can be done with the built in dependency editor.
In any case. As bwldrd said maybe creating them as conformers is the way to go. Actually the most sensible for a couple of reasons, not least being end user friendliness. There were a few others here trying to do exactly as you are now... With L'Homme. A forum search with fibremesh beard or brows as the search term might save you some headaches and stumbling around. If I remember correctly there was some reasonable success with a fibremesh beard...
primorge posted at 3:14PM Sat, 26 June 2021 - #4422087
Have you tried parenting to one of the control chips for the brows? It works, in an initial rudimentary fashion... but it will require additional steps, setting up JCMs and dependencies. This is basically what Nerd will tell you I imagine.
Yes, he and I spoke briefly about this. He sorta said the same thing. I wish it was as simple as in Daz studio. I may have a solution. But need to test it first. On dawn and dusk I never had a problem conforming fiberbrows. We will see.
In the fitting room, only transfer the rig. Not the morphs or anything. Then when back in Pose room save it down to library. Start new scene. Load LF and then the brows and now do the joint zones and transfer the morphs. Save down to library again.
"Dream like you'll live forever. Live like you'll die tomorrow."
Another tip: remember to go into the Body actor of your figure, go into its properties and tick the boxes that say "inherit scales" and etc. SPECIALLY if you want this to work with LH too - I had a 3 day-long nightmare of attempting to rig something like this because I didn't realize that.
Feel free to call me Ohki!
Afrodite-Ohki posted at 9:34AM Mon, 28 June 2021 - #4422142
Yes, i found that out too. I have found another sollution for this project. But i will come back with the fiberbrows some time. I had a discovery that you can rig them in Studio and they will conform in Poser. But you have to convert LH/LF for that first.
Hello all,
I made some brows for LA femme but cannot for the life of me find out how to rig the brows. Maybe someone got any ideas?
