Fri, Feb 7, 3:35 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
Subject: GoZ
adorety ( ) posted Mon, 28 June 2021 at 4:51 PM · edited Thu, 30 January 2025 at 10:22 PM
I just updated ZBrush to version 6.6 and did a full reinstall and uninstalled all previous versions of ZBrush. ZBrush is not seeing Poser and I can't figure out how to get Poser to see ZBrush for GoZ. I'm using Poser 12 and it worked fine prior to this. ZBrush support has no answer other than to look to Smith Micro because they have nothing to do with 3rd party versions. Anyone have a solution? Thanks.
Digitell ( ) posted Mon, 28 June 2021 at 5:40 PM
Forum Coordinator
Since you are using Poser 12, I am moving this to the Poser 12 forum. Maybe someone there can help you with this.
The Artistic Cat
hborre ( ) posted Mon, 28 June 2021 at 7:59 PM
I have no experience with ZBrush and it's connectivity with Poser but I would suggest consulting the Poser 12 manual found here and establish whether the instructions are similar to Poser 11. SmithMicro is no longer the parent company for Poser, Bondware is.
Liquid_Ice ( ) posted Tue, 29 June 2021 at 1:07 AM
You have to close poser and in zbrush update the install path of goz. I think you can do that under preferences — goz. Then restart zbrush and start poser.
722 ( ) posted Tue, 29 June 2021 at 3:32 AM
the only way i fix this is i had to reinstall poser so it would show up in z brush , i have went to z brush tech because when use go z with poser now it crashes reboot my computer , Z brush alone will crash after couple minutes of use, its either a driver or sad to say a hardware issue, suck i just got it back from the shop , just tap out of money to dill with a 500$ + part if its the motherboard lot cheaper if is my cpu dang ...
adorety ( ) posted Mon, 05 July 2021 at 12:22 AM
@722, I had a feeling that might be the case. Poser and Vue are not showing up in preferences GoZ list. Hopefully it all works after the update. Thanks.
