Thu, Nov 28, 1:14 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: M4 help
lakes123 ( ) posted Wed, 30 June 2021 at 3:52 PM · edited Thu, 28 November 2024 at 11:08 AM
I have a M4 figure with muscle morphs. My concern is the hips. Looks out of place. I feel its missing a muscle morph. I attached 2 images. The top is the original and the second is after the change. Did I miss something?
RedPhantom ( ) posted Wed, 30 June 2021 at 9:00 PM
Site Admin
that is definitely not right. I don't see the problem with my m4. You might need to reinstall the morphs and maybe m4.
ghostman ( ) posted Thu, 01 July 2021 at 3:09 AM
From the look of it the hip is not affected.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
lakes123 ( ) posted Thu, 01 July 2021 at 5:50 AM
RedPhantom posted at 5:48AM Thu, 01 July 2021 - #4422286
Didn't work. I removed M4 and the muscle morph and reinstalled them. No avail. I should note that the hip doesn't have the "Rectus Abdominus" morph.
lakes123 ( ) posted Thu, 01 July 2021 at 5:51 AM
ghostman posted at 5:50AM Thu, 01 July 2021 - #4422291
Exactly. The hip must be lacking something. But what? Did I miss something?
ghostman ( ) posted Thu, 01 July 2021 at 7:14 AM
does the morph work if you dial it in the hip? If not, the first I would do is to inject all the morphs again. If that doesn't work then I guess it is to reinstall.
lakes123 ( ) posted Thu, 01 July 2021 at 11:13 AM
ghostman posted at 11:12AM Thu, 01 July 2021 - #4422299
Is the hip supposed to have a "Retus Abdominus" dial. Its worth noting that the hip's Rectus Femorus dial does nothing.
primorge ( ) posted Fri, 02 July 2021 at 6:07 AM
Yes the hip is supposed to have the rectus abdominus morph. It will only display if you have Show Hidden Parameters checked in the Parameters options... accessed by clicking the little white right pointing triangle at the top right of the parameters palette...
primorge ( ) posted Fri, 02 July 2021 at 6:10 AM
I would reinstall. If you're curious you could check the deltas folder in the !Daz folder for M4 and see if this file is missing. That might not narrow it down though because Daz readscript files are kind of convoluted... just reinstall.
primorge ( ) posted Fri, 02 July 2021 at 6:33 AM
If that dial is present in the hip I would zero out the morph from the body, turn on master sync, and then dial it from either the hip or body.
lakes123 ( ) posted Fri, 02 July 2021 at 7:19 PM
Thank you very much primorge. All M4 users should know this.
