Poser 12 F.A.Q (Last Updated: 2025 Jan 19 10:19 am)
Select/cut the desired nodes. Exit the compound. Paste the selected nodes into the main material workspace. Delete the empty compound node. Select the desired nodes and collapse them to a (new) compound node.
P.S. your reflect and Blinn nodes are nonfunctional (see the dashed "wires"?)
OSes: Win7Prox64, Win7Ultx64
Thank. I was hoping there was a way without having to redo all the compound nodes.
I know the wires show that it won't work, but it does. I think those only indicators for Superfly, but I'm working with Firefly at the moment.
seachnasaigh posted at 1:23AM Thu, 15 July 2021 - #4423223
My skins setups are using one compound node connected to PoserSurface (the famous EZSkin3 setup) and one connected to a CyclesSurface node. Within the EZSkin3 compound, the nodes are connected using dashed "wires", but it also work with Superfly.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
EClark1894 posted at 1:25AM Thu, 15 July 2021 - #4423233
BTW, if I recall correctly, Poser's inputs and Outputs are actually reversed from whatever Blender material you're using. Drove me nuts. Another reason I haven't touched Poser in a while.
In fact, I've been told by a 3DS long-time user (before Windows even exists) that no products at the time were using the concept of nodes interconnected using dynamically represented wires, even 3D Studio Max, And Blender didn't existed yet.
And CuriousLab invented this for their Poser product (V5, V6? can't remember...).
If that's true, who is using inverted inputs and outputs?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I'm working on a material and am using compound nodes. Some of the shaders are similar so I copied and pasted them and then removed the unwanted nodes. Some of the unwanted nodes were connected to the external inputs of the compound node. Now they show as inputs even though there's nothing there. Does anyone know how to get them out of the inputs node?
For example, in these images, the blender and top diffuse shouldn't be there.
