Fri, Jan 31, 11:42 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Problems with RTX renderer
DarthJ ( ) posted Sun, 18 July 2021 at 3:26 PM ยท edited Fri, 31 January 2025 at 11:39 PM
Since Poser 12 I have the possibilty to use the Optix Geforce RTX renderer and everything was fine (and superfast compared with ordinary GPU rendering) until recently : now, after a few renders it just gives up, first only after having finished a part of the render, then completely. All you get is a grey or black image. You need to restart Poser to get it back working. Worse, it seems to bug some of the Poser files too, once a file failed a render, it will always fail. I wonder what causes this bug.
Digitell ( ) posted Sun, 18 July 2021 at 3:35 PM
Forum Coordinator
I have moved this to the Poser 12 forum since it is a Poser 12 issue
The Artistic Cat
Sunfire ( ) posted Sun, 18 July 2021 at 3:52 PM
I would suggest reporting the bug so the developers have record of it and can work on it.
Sunfire's Creations
ChromeStar ( ) posted Sun, 18 July 2021 at 7:27 PM
If you look in the log, do you have this error?
SuperFly: OptiX CUDA error CUDA_ERROR_ILLEGAL_ADDRESS in cuStreamSynchronize(cuda_stream[thread_index]), line 690
Symptoms as you describe. The render stops partway through, the remainder just goes black. If you do another render, it fails immediately and is all black. The original frame that caused it will always generate the same error; subsequent frames or other scenes may work if you restart Poser.
I was getting that a lot but it has been reduced in 12.500. Before, any frame that caused the error would never work with GPU rendering (Optix or not). Starting in 12.500, those frames now work in Superfly as long as I don't use Optix. That's a big improvement because rendering without Optix only takes twice as long, whereas CPU rendering is more like 10x. (I was originally having to reboot, too, but now restarting Poser is enough.) There are also fewer scenes that cause the error.
If you aren't already on 12.500, definitely update to that version.
Do report it though. They need example scenes that generate the error in order to troubleshoot it. It's very hard to fix an error if you can't cause it to occur on the test machines.
Y-Phil ( ) posted Mon, 19 July 2021 at 3:00 AM ยท edited Mon, 19 July 2021 at 3:01 AM
I am going to report the problem, too. From what I can guess, this seems related to Cycles2: I have a vic4, with a double setup: one with PoserSurface (no errors) and one with Cycles (crashed on rtx), the hair is based on PoserSurface
No hair, no problems, with hair and character on PoserSurface: no problems as well.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
ChromeStar ( ) posted Mon, 19 July 2021 at 3:41 PM
It's just not very predictable. I can have two frames of the same scene, same figures, same shaders, but one works and one doesn't. The pose matters. Maybe has to do with intersections/collision or something like that.
Y-Phil ( ) posted Mon, 19 July 2021 at 4:24 PM
ChromeStar posted at 4:23PM Mon, 19 July 2021 - #4423488
Aha... Pretty much what I was thinking, too
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
ghostship2 ( ) posted Mon, 26 July 2021 at 10:55 PM
I've been getting this same CUDA error at random for a few months. I've already reported my issue. My specific problem sometimes only shows up after working on a scene for a day or more then I add a single prop and all hell breaks loose and all I get is render crashes from that prop. Sometimes changing the mats on the prop will fix it and sometimes it does not. I've gotten the crash with my free super shader and other times it renders just fine. It's very hard to pin down what is happening.
