Sun, Nov 17, 12:20 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: running hourglass type dialog
FVerbaas ( ) posted Tue, 24 August 2021 at 11:42 AM · edited Sun, 17 November 2024 at 10:00 AM
Forum Coordinator
Scripting is notorious for being slow to process, Python is relatively good but still a scripted system, so users waiting completion of a task is nothing new. So this makes me wonder:
Is there a standard easy way to make a sort of dialog or alert with animated hourglass show up while my process is running? Some methods I can call to set or drop the message and the message dropping automatically when my script dies?
I guess it does require spawing threads and watches. I'd rather go by a proven solution than invent something bad myself.
adp001 ( ) posted Tue, 24 August 2021 at 2:40 PM
Check out wxPython's dialogs in the online documentation. Starting with "BusyInfo".
FVerbaas ( ) posted Tue, 24 August 2021 at 3:09 PM · edited Tue, 24 August 2021 at 3:16 PM
Forum Coordinator
Great. Thanks!
Images are not supported, alas, let alone images that are animated.
adp001 ( ) posted Tue, 24 August 2021 at 3:23 PM
FVerbaas posted at 3:19PM Tue, 24 August 2021 - #4425984
Great. Thanks!
Make a standard dialog with all features you need. Wrap the Dialog with a similar class as BusyInfo does with it's simple dialog.
FVerbaas ( ) posted Wed, 25 August 2021 at 9:01 AM
Forum Coordinator
Thanks. Was already afraid so. Other priorities prevail for now so the hourglass goes on the wish list.
adp001 ( ) posted Wed, 25 August 2021 at 9:21 AM
I bet someone has done this allready. wxPython is a framework not only used with Poser and has thousends of users and contributors. A Poser forum may simple be the wrong place to ask.
FVerbaas ( ) posted Wed, 25 August 2021 at 9:28 AM · edited Wed, 25 August 2021 at 9:29 AM
Forum Coordinator
Yes, definitely it will be there somewhere. Will be looking further before I sit down to write and report when I found something.
