Sun, Jan 5, 8:03 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
Subject: Moho 13.5
Wilks ( ) posted Sun, 29 August 2021 at 2:33 PM ยท edited Sun, 05 January 2025 at 4:12 AM
Hi guys.
I have Poser 12. I am thinking Poser 12 support Moho 13.5? I mean I can import my Poser 12 file into Moho 13.5? I had Poser pro 11 and Moho 12 and they "worked" together. Sry but I can not find any information about this situation.
Digitell ( ) posted Sun, 29 August 2021 at 2:36 PM
Moving this to the Poser 12 forum
Y-Phil ( ) posted Sun, 29 August 2021 at 3:20 PM
From what I've seen, Moho seems to support FBX. Have you tried an exchange between Moho and Poser using this?.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
HartyBart ( ) posted Sun, 29 August 2021 at 5:37 PM ยท edited Sun, 29 August 2021 at 5:38 PM
Dug up from the forums:
"I just upgraded to Moho 13 and saw that the Poser plugin was dropped because of license issue."
"Sad to see the Poser import is gone, and raster to vector. Is it possible to get them working using the Moho 12 script for Poser import?"
No, was the answer. Though the same script still works for Poser 11 to Clip Studio EX.
But Moho now has new owners (sold back to the original developer duo). They might bring back Poser import if Renderosity encouraged them?
EVargas ( ) posted Mon, 30 August 2021 at 7:40 AM
Poser 12 has some decent export options. I understand that a "one click" script is always tempting but you surely have some alternative. Maybe @Wilks could add more info about what kind of content he usually transfer to Moho then we suggest something?
EVargas.Art
HartyBart ( ) posted Tue, 31 August 2021 at 4:00 AM
Would it be possible to import Poser content to Moho 12.5, save the file as Moho, then open the file in Moho 13? Or were the connections that Moho 12.5 hooked into Poser dynamic, rather than making a portable Moho file with all the content inside it?
Wilks ( ) posted Fri, 03 September 2021 at 8:56 AM
Thank you guys for helping. I do not have Moho 13 yet. I have only Moho 12 and Poser 12.(after upgrade Poser Pro 11) I was just thinking Moho 13 can accept directly Poser 12 saved files or not. I got some usefull information from you. I will try "FBX", etc,etc files.And thanks that information Moho 13 got a "new owner".
Wilks ( ) posted Fri, 03 September 2021 at 9:06 AM
evargas posted at 8:59AM Fri, 03 September 2021 - #4426289
Thank you for your help too. The main problem is some Poser 12 saved file not working with Moho 12.(like "Le-femme").I want to do upgrade from Moho 12 to Moho 13 but I wanted to make sure Poser 12 can "work" together with Moho "easily". But I will try the other files format too. Thank you again for your helping guys.
DCArt ( ) posted Fri, 03 September 2021 at 12:43 PM ยท edited Fri, 03 September 2021 at 12:50 PM
This is a question that is probably better asked to the Moho programmers, since Moho 13.5 was fairly recently released. Since Moho supports direct import of Poser format, the support for Poser 12 import may need to be updated in Moho for Poser 12, and not vice-versa.
Thankfully, Moho is now back in the hands of the original programmers instead of Smith Micro, and I believe they still have their support forum on LostMarble. You can find out more here:
https://moho.lostmarble.com/
Y-Phil ( ) posted Fri, 03 September 2021 at 1:03 PM
If you have a poser 12 file to import, you may also do a simple test: using a text editor change the version number in its header. Poser11 can read Poser12 scenes, it just ignores what it doesn't recognizes
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
