Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
A Python script can juggle the Comic Book options on and off, but it's not too useful since it takes artistic judgement to set the dials, in combined interaction with the lighting. Plus you have to get the lighting itself done right, and then there is no way for a script to control some things like Preview Shadow Maps Size. So basically you can't automate that creative part of the setup for the users. And without that they're going to just automate the output of crap.
The others are Firefly, which again can be done by a script but it needs to be done right or the renders are going to take a long time to render compared to the fast realtime Comic Book. Getting it really fast, at the size of render you want for the frames of a print comic, assumes the user has a certain type of computer. And then it's not just a matter of setting the switches you've circled, but you also need to know and set all the scene.CurrentFireFlyOptions control commands. There is a standard script which ships with Poser which gives access to these though, in Partners / D3D / Render Firefly, which should give you some pointers.
If you have saved the movie sequences in PZ3 files and want to use the same render and movie settings for all of them, you can work around this by deleting the corresponding data from the files. These are:
1. movieInfo (at the very beginning of the PZ3 file)
2. renderDefaults (at the very end of the PZ3 file)
If you load such a modified file, the last settings will be used.
Make sure that you remove everything inside the curly brackets, the keyword and the brackets.
But be careful: when you save the loaded file back, Poser will add the missing information again and you will have to do the deletion again.
It might be problematic if you don't have an editor that can handle large files. Then only a script that does the cutting helps.
Hi friends, there are some options that are not documented in any Poser manual, I would like to know if it is possible to access those options through python scripts.
Some of the options are these:
and these:
does anyone know how to access through python scripts?
