Sat, Jan 25, 12:31 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Load FBM from Geometry in Python?
Iuvenis_Scriptor ( ) posted Wed, 17 November 2021 at 3:01 PM · edited Thu, 23 January 2025 at 12:07 PM
Does anyone know the Poser 12 Python method for creating an FBM from an OBJ file (essentially a scripted version of the "Load Full Body Morph" menu command), if it exists?  I'm trying to write a script that restores transgender morphing capability to La Femme.  Thanks in advance for any tips!
adp001 ( ) posted Wed, 17 November 2021 at 4:04 PM
Not exactly what you are looking for, but the code contains anything you need:
https://adp.spdns.org/#ObjImExport
structure ( ) posted Wed, 17 November 2021 at 4:45 PM
Forum Coordinator
poser.ProcessCommand(1484) will create a full body morph from the currently selected figure,
poser.ProcessCommand(1485) will reload that morph back to the currently selected figure.
Locked Out
FVerbaas ( ) posted Fri, 19 November 2021 at 10:08 AM
Forum Coordinator
The ProcessCommand calls still present the user with a question to select the obj file to load.
 I would expect  @luvenis_Scriptor looks for a way to load a .obj file from a path given as an argument to the function without bothering the user.
