Sat, Feb 15, 2:59 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Name of the file PZ3
minuitdixhuit ( ) posted Wed, 15 December 2021 at 4:56 AM · edited Sat, 15 February 2025 at 2:59 AM
Hello,
Is it possible in a python script to get the name of the current PZ3 file?
Thanks for your help.
M18
structure ( ) posted Wed, 15 December 2021 at 6:56 AM · edited Wed, 15 December 2021 at 6:59 AM
Forum Coordinator
import poser
scene = poser.Scene()
document = scene.DocumentPath()
if document is None:
    document = "Untitled"
Locked Out
minuitdixhuit ( ) posted Wed, 15 December 2021 at 9:24 AM
Maaaaaaaaaaaaaaaaaaany Thaaaaaaaaaaaaaaaaaaaaaaaaaaaaanks !
Work fine !
structure ( ) posted Sat, 18 December 2021 at 9:06 AM · edited Sun, 19 December 2021 at 6:31 AM
Forum Coordinator
another way
import poser
def get_document(scene):
    return scene.DocumentPath() if not scene.DocumentPath() is None else "Untitled"
document=get_document(scene)
Locked Out
adp001 ( ) posted Sun, 19 December 2021 at 9:26 AM
structure posted at 9:06 AM Sat, 18 December 2021 - #4432058
another way
import poser
Sorry for the " lecturer mode": but this is a good example of when you achieve a degradation with supposed code optimizations.
The function that returns the result is always called twice. Just to save one line of code.
The better (and more readable) way:
  d = scene.DocumentPath()
  return d if d else "Untitled"
(In the end it's even less typed keys :))
adp001 ( ) posted Sun, 19 December 2021 at 9:42 AM
Ok, i missed that scene.DocunebtPath() can return None.
The last line should be:
  return d if d is not None and d else "Untitled"
adp001 ( ) posted Sun, 19 December 2021 at 10:01 AM
A test for None should always look like this:
  <statement> is None
or
  <statement> is not None.
But not:
  not <statement> is None
Why?
Once, because it is recommended by the Python documentation :).
And if you think about it, you will see that from <statement> the value is evaluated and then negated. The result is then checked for None (== None). If you write it correctly, the parameter is directly checked for != None. Which is of course more effective, and depending on what is behind <statement>, possibly also much faster.
