OK, but let's use some examples. 1.) I'm going to submit a render/picture for the 3D-CC monthly contest. 2.) I'm entering a Renderosity Contest 3.) Someone else's contest. 4.) I want to submit a great looking picture to my Renderosity gallery. Do any of these examples call for a different strategy in rendering, saving, etc?
I save as .tiff format because you get a great alpha mask that you can select only the rendered figures/objects with. Great for compositing images. As for render size, I usually go with atleast a 1200xwhatever image. A larger image is better, even if you have to scale it down, because more detail is retained. Shadows.... the render itself dosen't cause bad shadows, what you need to do is adjust the map size on the lights, and turn the shadow value down from the default 1. I use a 2048 map size and .3 shadow value.
OK, so far it seems .tif format is preferred. If I wanted to submit an entry to a contest, then I could load the tif image (say in PhotoShop), reduce it in size if necessary, then save in jpg?! Is there any reason for not using the .pdf (native PhotoShop) format? Or don't you have PhotoShop? I'm just trying to figure if the tif format has more features available than pdf. Is there a concern about how big the tif files are? My 20GB hard drive gets a bit full sometimes.
If I understand your concern correctly, you're looking for render/saving settings to satisfy your two primary desires: to save a great pic and for contest submission. I assume you mean to save in the best resolution you can get and at a compressed size to upload. If I got that right, I would only concern myself with resolution--a great pic to save. I ALWAYS render/save at best resolution, usally tiff format (I refer to it as an archive master). From a pic editior, you can adjust the master and save it separately to meet the other (contest) requirements.
![file_225283.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_225283.jpg)
I've been trying to figure this one out. I do my art for art's sake, but sometimes I enter contests, such as the Halloween Contest at Renderosity, and the monthly contests at the 3DCC. So far I have been using what appears to be the default rendering options, except I use the New Window option. Sometimes I choose to Render Shadows, but often that makes the picture too dark.
