Sat, Dec 28, 8:48 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Undo option disabled
maur_2005 ( ) posted Thu, 03 March 2022 at 4:07 PM · edited Sat, 28 December 2024 at 8:46 PM
Hi folks, I have noticed that sometimes after running a script the Undo option becomes disabled and I can't undo what the script did. Does anyone know why this happens and how to fix it?
structure ( ) posted Fri, 04 March 2022 at 8:23 AM
Forum Coordinator
this seems to be an intermittent "bug" I am not aware of any way of how to fix it. Perhaps petition Bondware to add a feature that saves/loads the history to a file as photoshop can do.
Locked Out
FVerbaas ( ) posted Sat, 05 March 2022 at 2:33 PM
Forum Coordinator
Not sure if script actions are supposed to be 'undo-able'. Undo typically works via incremental changes. A script can make many changes and it would require a complete save of the scene.
