Tue, Nov 26, 4:36 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: SublimelyVexed Zora for La Femme
fluffykatt ( ) posted Sun, 10 April 2022 at 7:34 PM · edited Tue, 26 November 2024 at 2:08 AM
Hello I am trying to use SublimelyVexed Zora for La Femme for the first time since I bought her & no matter what pose I use she renders crossed-eyed, how do I fix this. I have been trying all day. I usually use V4 but I am trying to learn how to work with La Femme since I have bought a bunch of La Femme products.
Rhia474 ( ) posted Sun, 10 April 2022 at 7:48 PM
The only thing I noticed in the description is that this is a product for LaFemme PRO. Is that what you are using as a base? Outside of that as I don't own this morph package, I'd suggest perhaps take a look at the eye actor and see if any of the dials are offset that you can manually adjust? Or, some screenshots here ?
hborre ( ) posted Sun, 10 April 2022 at 9:29 PM
I don't think there is any difference between the Poser legacy version and LaFemme PRO.  I do believe that the PRO version was released before she was bundled into Poser but I could be wrong.  Although I don't own this package, the included Readme documentation does not address any morph problems nor any further requirements needed for this particular morph to work.  I would suggest screencap the before and after images and contacting the vendors.  You may be the only one reporting a problem but I think it is worth notifying the creators of this content of a potential bug.
Y-Phil ( ) posted Mon, 11 April 2022 at 5:13 AM · edited Mon, 11 April 2022 at 5:13 AM
Just a small question: check if La Femme's eyes are not pointing to... something?
Sorry... I couldn't help but...  rMQHwYzU5wekWdR9oKWiaynYSu0Du1YKS9KbIXZO.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
fluffykatt ( ) posted Mon, 11 April 2022 at 5:49 PM · edited Mon, 11 April 2022 at 5:51 PM
I know there is some way to fix the eyes but since I haven't been working with LaFemme I couldn't figure it out. I finally started over & used a new doll & I finally got a good render. I will have to see if I can find out about the eyes so if I get this again I will know how to fix it because everything I did just made it look worse. Thank you for your comments, I guess I will have to site mail the artist & see what they can do to help me. I am using LaFemme PRO.
3DSublimeProtege ( ) posted Mon, 11 April 2022 at 10:43 PM
Forum Moderator
I will look into this for you, as we didn't have any issues with it :)
3DSublimeProductions (Tima) - Admin, Vendor, Marketplace Tester, & Vendor Education
3DSublimeProtege ( ) posted Mon, 11 April 2022 at 10:54 PM
Forum Moderator
OK. I had to dig into this before bed :)
I loaded LF Pro into Poser 11 and Poser 12
Applied the head morph (dialed in from the body)
Applied pose... eyes worked well
Apply the body morph (dialed in from the body)
Applied pose.... eyes worked well.
Not sure what is going on on your end - is your poser up to date as far as updates go?
fluffykatt ( ) posted Tue, 12 April 2022 at 8:27 PM · edited Tue, 12 April 2022 at 8:29 PM
3DSublimeProductions, Thank you for answering my post. I'm sorry to take so long to get back to you but Tuesdays is my Chemo day. I'm using Poser Pro 11, which I updated when they put out the last update but they no longer have updates for 11 since 12 came out. I'm using La Femme Pro & the Firerfly render. I'm sorry to have bothered you, I thought someone in this form would know how to adjust the eyes & maybe tell me if there is a tutorial on how to do that.
hborre ( ) posted Tue, 12 April 2022 at 9:30 PM
One thing I can suggest is to do a restoration of just the eyes without affecting any of your morphs.  Select the eye and on the Preview window, right-click to call up the contextual menu.  Go down the list and highlight Restore, another menu will open, select Object to restore it to its default settings.  Afterward, you can manually reposition the eye to your intended pose.  Now the wonky eyes might be a crosstalking event with another morph you're trying to apply but I don't know if is the case with your problem.
fluffykatt ( ) posted Wed, 13 April 2022 at 4:48 PM
Thank you all for your replies. I went back & deleted LaFemme & started over, this time the doll rendered without the crossed eyes, I think maybe in the original try I may have made too many changes because I found out if you do that with V4 it can cause the figure to do crazy things, so maybe it is the same with LaFemme, my indecisiveness may have caused the problem. Thank you all again for the help.
