Fri, Jan 10, 8:16 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Scripted CR2 Saving Causes Poser to Exit
Iuvenis_Scriptor ( ) posted Mon, 25 April 2022 at 12:36 PM · edited Fri, 10 January 2025 at 5:47 PM
I've encountered quite a mystery in Poser 12.0.757.  I'm working on a script that starts out like this:
import os
import poser
loc = os.path.dirname(os.path.abspath(__file__))
lib = loc.split("Materials")[0]
fig = os.path.join(lib,"Character\Genesis 8 Male\Characters\Iuvenis_Scriptor\Calisto")
scene = poser.Scene()
figure = scene.CurrentFigure()
scene.SaveLibraryFigure(os.path.join(fig,"Calisto.cr2"))
The odd thing is that, when it reaches the last line reprinted above, Poser thinks for a bit and then just closes.  No error message or anything.  It just exits, as if I'd clicked the X in the top right corner of the window.  And yet, when I do the exact same thing manually (via the '+' button in the Library palette), it works just fine.  The same code (with paths and filenames appropriately adjusted) also works just fine on La Femme, but not on a converted G8M.  I'm at a loss, so I'd be thankful for any tips!
Y-Phil ( ) posted Tue, 26 April 2022 at 1:21 AM
I suppose that your scripts lies at "runtime:library:", wherever it is on your computer, hence my silly question:
I suppose that the relative path "Genesis 8 Male\Characters\Iuvenis_Scriptor\Calisto" exists?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
FVerbaas ( ) posted Tue, 26 April 2022 at 7:31 AM · edited Tue, 26 April 2022 at 7:31 AM
Forum Coordinator
That is likely to be the issue indeed. One should always check the existence of the path before trying to read or write it.
at least put a try/except: around any operation on files to minimize surprises like you experience now.
