Tue, Jan 7, 3:17 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
Subject: Marilyn morph
mdbruffy ( ) posted Sat, 11 June 2022 at 7:58 AM · edited Sun, 05 January 2025 at 2:09 PM
Anyone know where I can find a Marilyn Monroe morph for V3 or V4? I need the dress, too.
Rhia474 ( ) posted Sat, 11 June 2022 at 9:04 AM
VedaDalsette ( ) posted Sat, 11 June 2022 at 10:51 AM · edited Sat, 11 June 2022 at 10:51 AM
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
Rhia474 ( ) posted Sat, 11 June 2022 at 11:09 AM · edited Sat, 11 June 2022 at 11:09 AM
I had the character and the hair already, so quick and dirty Superfly render after running it through EZSkin3:
mdbruffy ( ) posted Sat, 11 June 2022 at 11:14 AM
VedaDalsette posted at 10:51 AM Sat, 11 June 2022 - #4439841
Dress in Freestuff.
https://www.renderosity.com/freestuff/items/70528/marinas-dynamic-dress
Sorry. I should have been more clear. I need that white one.
mdbruffy ( ) posted Sat, 11 June 2022 at 11:15 AM
Rhia474 posted at 11:09 AM Sat, 11 June 2022 - #4439842
Looks good. Hope I can get my version to look that close.
RedPhantom ( ) posted Sat, 11 June 2022 at 12:49 PM
Site Admin
I found 2 dresses for Daz and g8 if you don't mind converting,  a free one here and a pay one here
mdbruffy ( ) posted Sat, 11 June 2022 at 1:16 PM
RedPhantom posted at 12:49 PM Sat, 11 June 2022 - #4439850
Unfortunately, Poser  12 doesn't do deforce.  And I don't have the programs needed to convert it. But thanks anyway.
Rhia474 ( ) posted Sat, 11 June 2022 at 2:46 PM
Lily dress over at Daz is pretty close, just add a white material. Trying to do something now.
mdbruffy ( ) posted Sat, 11 June 2022 at 2:47 PM
Rhia474 posted at 9:04 AM Sat, 11 June 2022 - #4439837
https://www.renderosity.com/rr/mod/bcs/sav-marina/97409/
Hair:
https://www.renderosity.com/rr/mod/bcs/sav-marina-hair/98562
Not sure about THE dress, maybe someone else has it.
The morph files I got from your link are all .pz2 files. How do you inject a .pz2 file?
Rhia474 ( ) posted Sat, 11 June 2022 at 3:14 PM · edited Sat, 11 June 2022 at 3:17 PM
Um, you install to your Poses folder then you load V4, go to the SAV Marina folder and click on the INJ icon?
Rhia474 ( ) posted Sat, 11 June 2022 at 3:31 PM
Again, this is a nonfinal render in Superfly:
mdbruffy ( ) posted Sat, 11 June 2022 at 4:07 PM
Rhia474 posted at 3:14 PM Sat, 11 June 2022 - #4439856
Um, you install to your Poses folder then you load V4, go to the SAV Marina folder and click on the INJ icon?EJRo0zGBupofHNavp8Acn7pZpS4m4tV7ccThY7fV.jpg
Not only am I facing this problem, but I went directly to these scene files and opened one. It uses LaFemme, not V4. I tried injecting the files into Lafemme and she wouldn't take them either.
Rhia474 ( ) posted Sat, 11 June 2022 at 4:15 PM
I'm sorry. The link I gave you is a V4 character morph.  If you install in Poser 11 or 12 via Piser's built in installer, it looks nothing like your screen.
Can you walk me through how you installed the zip files that you got? And show me what the zip files look like? I have no scene files in my install zips for this character.
RedPhantom ( ) posted Sat, 11 June 2022 at 4:17 PM
Site Admin
I've used D-force in Poser. I loaded the dress in DS, exported it as an obj, then imported that into Poser used the morph brush to fit it to the figure I wanted to use and used the clothroom to drape it.
Rhia474 ( ) posted Sat, 11 June 2022 at 4:23 PM · edited Sat, 11 June 2022 at 4:23 PM
I have these zip files from the purchase of that item:
I download them to my computer into my Download folder.
In Poser, I use the File-->Install from Zip Archive command.
I then select the runtime I want to install into, in this case I chose my 'Victoria4' runtime I already had.
I repeated this step for all 4 ZIP files.
I then refreshed my runtime and everything was there. I then pulled a V4 into my scene (or in my case I used a Saha-4 weightmapped version of V4) and navigated to the Poses-->Victoria4-->SAV-->Marina folder in my Library and it was seamless. Not sure what steps you followed.
mdbruffy ( ) posted Sat, 11 June 2022 at 4:25 PM
I downloaded the files like I always do. I prefer to manually install my files cause if I don't, they don't always go where I can find them. Then I opened the zip files and placed the files in Poser:
 I even came directly here and opened some of them and they use LeFemme instead of V4. Thing is, neither figure will take them.
mdbruffy ( ) posted Sat, 11 June 2022 at 4:42 PM
Rhia474 posted at 4:23 PM Sat, 11 June 2022 - #4439863
I downloaded all 4 files just like y9ou did. But, I manually unzlipped the files and installed them. The material files are in materials, the prop files for the hair are in props, and the morph files are in Pose. But they won't work.
Rhia474 ( ) posted Sat, 11 June 2022 at 4:58 PM
Perhaps try the method I suggested above and see if they do work then? I never remove bare files from their folders and move them around that can mess things up. When I install manually, I always leave things in the folders they came in. There may be some paths that got confused and are looking for files that aren't where the reference paths tell them to be.
With manual install (files from DAZ have to be manually moved in my opinion) I just grab the Runtime folder from the zip and drag and drop to the runtime folder I want them in. With correctly done folder structure (I had freebies that were messed up but no paid-for content from a site I knew) everything propped into its place just fine.
mdbruffy ( ) posted Sat, 11 June 2022 at 5:03 PM
Rhia474 posted at 4:58 PM Sat, 11 June 2022 - #4439867
I manually install everything. Normally, I don't have this kind of problem. They're not looking for missing files, they just refuse to install. And if the morphs are intended for V4, why is LaFemme in the files?
Rhia474 ( ) posted Sat, 11 June 2022 at 5:10 PM
I have no idea. All I know is that they work fine for me and there is no issue with them ever referring to La Femme whatsoever. The only difference I see between the two installs is that you added them into a different file structure.
Since repeating 'they worked for me with the method i described' is counterproductive, perhaps someone else can help you?
mdbruffy ( ) posted Sat, 11 June 2022 at 5:45 PM
Rhia474 posted at 5:10 PM Sat, 11 June 2022 - #4439869
Thanks for trying.
RedPhantom ( ) posted Sat, 11 June 2022 at 9:56 PM
Site Admin
First, don't double-click on pz2 files from explorer. It doesn't work. It only ends up reloading the default scene. If you want to use explorer, try dragging and dropping instead.
However, those files you posted are the wrong ones. Those aren't the ones that should be in the library. Those are the files that the morphs you want will reference. If you notice, those files have no thumbnails. those should be in \Runtime\Libraries\Morphs\StudioArtVartanian\MarinaMorphs\ not your poses folder. Look at the read me for the files you want in the pose folder. They all start with a number or an !.
You can try to move things around manually, but I recommend deleting everything and then using the purchase tab and letting poser install this one for you since there are a lot of files that need to be in the runtime, but not in your usual library folders. Then go to the purchases runtime in explorer and drag everything to the runtime of your choice, keeping all the paths intact for any of the extra files, like you would for geometry or texture files.
mdbruffy ( ) posted Sat, 11 June 2022 at 11:36 PM · edited Sat, 11 June 2022 at 11:55 PM
RedPhantom posted at 9:56 PM Sat, 11 June 2022 - #4439872
Finally got her. Only had to move the "Marina" file. Therest became a case of tracking down the delta files.
I had to use the prop hair- the character version is a Daz file- needs some adjustment yet. Now I just need the white dress.
qaz ( ) posted Sun, 12 June 2022 at 8:13 AM · edited Sun, 12 June 2022 at 8:13 AM
Interesting this topic should come up as I was in the process of assembling decent photos of Marilyn to upgrade an old morph I did. I certainly think it can be improved.
If you want I may be able to provide an injection morph. From memory I used the original SAV texture.
mdbruffy ( ) posted Sun, 12 June 2022 at 9:07 AM · edited Sun, 12 June 2022 at 9:08 AM
qaz posted at 8:13 AM Sun, 12 June 2022 - #4439892
Looks real good. Did you use the Marina Hair? That looks good. Here's what I have so far. The Marina morph and hair- the prop since the character is for Daz-. I also used the Scarlet dress for V4 and the sandals from Business casual.
qaz ( ) posted Sun, 12 June 2022 at 10:09 AM
mdbruffy posted at 9:07 AM Sun, 12 June 2022 - #4439893
The hair is very old Portia hair. My character never had any clothes !
mdbruffy ( ) posted Sun, 12 June 2022 at 10:20 AM
qaz posted at 10:09 AM Sun, 12 June 2022 - #4439895
Portia Hair. I  missed that one some where along the line and I've been using Poser since Poser 5.
qaz ( ) posted Sun, 12 June 2022 at 11:03 AM
If we are talking about 'the dress scene'
I guess this would be it. going cheap.
https://www.renderosity.com/rr/mod/bcs/pleateddress-for-v4a4g4elite/102167
mdbruffy ( ) posted Sun, 12 June 2022 at 12:16 PM
My post didn't show or reveal anything. Why was it removed?
mdbruffy ( ) posted Sun, 12 June 2022 at 12:49 PM · edited Sun, 12 June 2022 at 12:49 PM
mdbruffy posted at 12:16 PM Sun, 12 June 2022 - #4439900
I 'll try this again. Maybe if it gets pulled this time, someone will tell me why.
