Sun, Feb 16, 5:29 PM CST
Renderosity Forums / MarketPlace Customers
Welcome to the MarketPlace Customers Forum
Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2025 Feb 14 7:40 am)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Subject: Problems getting Poser 12 and La Femme products to work
Hydra ( ) posted Tue, 21 June 2022 at 2:09 PM · edited Mon, 03 February 2025 at 12:53 AM
I recently purchased quite a few characters and clothing products for La Femme.  I am using Poser 12 on a Windows 11 system.  I cannot seem to get any of the clothing products for La Femme to work with any of the characters for La Femme that are sold here.  The Mesh's break apart or distort to the point of being of no use when they are conformed to the characters with the character morphs copied to the clothing.  And they certainly cannot be fitted to the character without copying the morphs over as far as I can tell.  Is there a trick to get this stuff to work?  I've also noticed some of the La Femme characters for sale have images in the description that depict the character wearing V4 outfits, how the heck do you make those fit?  I figure I must not be doing something right.  Or I simply need more knowledge about how to make these products work properly.  Any suggestions?
Thanks!
Hydra
Kalypso ( ) posted Wed, 22 June 2022 at 10:13 AM · edited Wed, 22 June 2022 at 10:16 AM
Site Admin
Can you be a bit more specific?  An example of a character morph and a clothing item that would not work even with the morphs copied over would be a good place to start so we can figure out what's going wrong.
As for fitting clothes from V4 to La Femme there are several ways.  One of the quickest and easiest is Crossdresser.  You need to download it from the creator's site and buy only the La Femme plugin  from here
Hydra ( ) posted Wed, 22 June 2022 at 12:57 PM
Crossdresser causes all V4 clothing converted to La Femme to be translated below the character when it is conformed to La Femme, and I don't know how to correct that issue.  I've tried all the kung-fu I know from my experience using Poser since buying a copy of Poser 3.0 off the shelf at a Best buy in 1994.  I have not had good results with that Crossdresser 4.0 or it's Morph creating companion software.  To be more specific with the problems I am having in Poser 12, one example is Tempesta 3d's Dorotea figure, go ahead and try to get any tight-fitting clothing for La Femme to fit her and you should be able to see what I am talking about.  But the problem is certainly not just with Tempesta 3d's characters, I have the same problem with EVERY character I have purchased for La Femme.  Like I said, the problem is probably at my end, I just have not figured out how to make them work.  I must be missing some information on how Poser 12 and La Femme stuff works.  So far, I have spent many hours in trial and error trying to set up each figure and I have not had much luck.  I have purchased 29 characters for La Femme so far in the past two weeks, I have had very little success in getting them dressed.  Again, I am specifically referring to tight clothing.  A colorful potato sack is easy to fit to any character.  Thanks!
Hydra
LadyElf ( ) posted Thu, 07 July 2022 at 3:56 AM · edited Thu, 07 July 2022 at 3:58 AM
One thing I would do is contact the creator of Crossdresser and show her images of your problem.  When you are conforming the clothing is La Femme in default position?  do you have Poser 11 that you could try this in to see if it works there?  As far as I know there is no difference in how they work from version 11 to version 12. It could be something as simple as the clothing do not support the body morphs in the character that you are using.  I've plenty for V4 that ended up being that way.
Not sure if you have this problem solved since your last post, but would be more then happy to see if I can help, I understand the frustration for sure!
hborre ( ) posted Thu, 07 July 2022 at 6:02 PM
This is a quick render of La Femme wearing a V4 outfit created by AS and converted by me through Crossdresser.  It is a conforming outfit and I was able to transfer LF morphs to it using the P12 Copy Morph feature.  One important tip when converting any outfit across different models is always copy the joint zones from the model you are conforming the outfit to.  Otherwise, you will get strange anomalies occurring throughout the mesh.  I have converted this same outfit for use with Dawn, Miki 4, Victoria 3, and Laura with the same degree of success.
