Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
It happens to me, from time to time, even with more recent stuff.
Most of the time, I change the texture display value so that it corresponds to the biggest bitmap size.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Regardless of whether your platform is a MAC or PC, on the upper-right-hand corner of your Library panel there are these icons: . Those will link/unlink the external runtime folders on your system. In this case, the Poser 10 runtime folder would become the external runtime folder to Poser 12. Otherwise, as you have discovered, all your old scenes are searching for files that are not connected to the Poser 12 Library.
And as DCArt posted, overwriting a new runtime with an old one is asking for disaster.
Regardless of Mac or Win, this should be same.
Open your Poser 12.
Make sure you open your Library by clicking on the Library icon (stacked books looking icon) in upper right of screen.
Find the Add Library icon that looks like what hborre posted above. Click it.
Navigate to the folder in the menu that opens that houses your Piser 10 Library (depending where you installed those these can be in your Documents under Poser 10 or elsewhere... you may need to do a search for folders called 'runtime' to locate and you must choose the folder that is a level above the Runtime folder).
Depending on how you installed content, you may gave multiples, and in order to use older work files you created in Poser10, you need to find where those are. The work files only contain references to where the actual content is located.
I hope that makes sense a bit.
Major advantage of using external libraries for all but the most 'core', frequently used items is so they do not clutter Poser's in-house run-time folder tree, may be easily culled...
My 'as required' external libraries are spread across three big drives, 1TB E:+ F:, 4TB G:, would be utterly unprintably unmanageable were I to stuff contents into Poser's Runtime on C: Besides, they simply would not fit...
I just upgraded to Poser 12 after a year of hassle, and found that all my Poser 10 files have problems. The biggest thing is this - the objects all appear, but the characters do not (they seem to be invisible, and not listed on the scene elements), although there are indications there is some memory of them being there (interface points, etc.). Now, some of the characters that were in those scenes are OLD...P5 figures...so that may be a problem, but I was wondering if anyone has encountered this and/or has some suggestions for solutions.
Thanks!
DE
