Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 7:06 am)
I think that the Dome was already included in Poser2010's content, but you don't need it if you use the background node, especially if you change the second parameter of the location of the Mapping node: 0, 0.2, 0 = 20% higher for all the scene, except the HDR bitmap.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Looks like I was wrong because I wasn't as organized with my runtimes as I am, sorry for the confusion.
Just be careful: only Terradome 1&2 are compatible with Poser, the V3 will need to be converted.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
V3 I believe didn't come out until after RDNA moved to Daz and was the DS compatible one.
You seem to misunderstand, there is a Poser version and it is available in the DAZ store. Check their webpage. Poser is clearly mentioned under 'Compatible Software". There is no need to approach the creators on this issue, they sold the rights to DAZ3D and you can purchase a Poser working version and all the associated modules. And as I mentioned above, you missed your opportunity to save 60% on each bundle and module over the holidays.
TerraDome 1 and 2 works perfectly fine in Poser. As hborre mentioned, v3 seems to be DAZ only, but that doesn't mean 1 and 2 are obsolete since they are for a different software. TD2 even has a TerraLuna extension that helps you to make space renders.
ETA: I looked at TD3--it seems almost 100% a rework of what TD and TD2 offers to Poser users.
(29) TerraDome 2: The Badlands - YouTube
(29) TerraDome 3 For Daz Studio Iray - Overview - YouTube
Here are the promo videos that were made for each version. I have both Terradome 1 and 2 and most if not all the extras. Really sad when RDNA shutdown and this system got froze in time. Personally TD2 has the better video in that it makes you want to do something with it. Especially the morph terrain as the camera flys byvs here what the sliders do.
A quick P12 Superfly rendering converting materials to PhysicalSurface PBR, eliminating the IBL and specular lights, and converting the point light to infinite Blackbody sunlight. The skydome could use the HDR touch, perhaps converting the JPG to HDR might do the trick but that requires experimentation.
I wish I had bought one years ago at RDNA, but does anyone know if the Tera dome still works in Poser, or if Renderosity is planning an update on the system???
