Thu, Jan 30, 3:39 PM CST
Forum Moderators: Staff
Subject: Reduce the number of meshes
Tekitoumen ( ) posted Wed, 06 July 2022 at 2:10 AM · edited Thu, 30 January 2025 at 8:34 AM
Hello.
I want to use the human model that Poser has.
I want to use the data exported by .obj elsewhere, but there are too many meshes.
The subdivision level is the lowest.
I want to reduce the number of meshes in the model even more.
How can I do it?
Also, is the subdivision level the only way to adjust the number of meshes?
If I import the model from outside, can I adjust the number of meshes?
If you know, please let me know.
Thank you.
Richard60 ( ) posted Thu, 07 July 2022 at 9:21 AM
Currently Poser cannot export a figure as a single mesh.  What do you want to do with the exported mesh?  Does it matter if there is rigging, or will a statue of the figure be enough?
Tekitoumen ( ) posted Tue, 12 July 2022 at 7:21 PM
Sorry for replying late.
I want to export the human body model created by Poser as obj data and import this obj data into another tool and combine it. However, since there are many meshes of the human body model, it is a problem that it takes time to process.
If the mesh of the model created by Poser cannot be reduced, I am thinking of editing it with a CG tool such as blender.
Thank you.
primorge ( ) posted Wed, 13 July 2022 at 5:48 PM · edited Wed, 13 July 2022 at 5:49 PM
If you just want the mesh as one contiguous object without separations at the body part groups, generally most contemporary Poser figures have such a mesh, as referenced by the cr2, contained in the Geometries folder of the figure in question Runtime. It will be in zero pose however.
There's also another option via export directly from Poser scene, posed or zero, that maintains groups (optionally), material regions, and UVs but will change the vertex winding order. The winding order is expected to match as initially created for original morph targets to work properly (the ramifications and solutions to this are a more involved topic)... If pre existing morphs are not important then...
For this demo I'll be using a posed La Femme Poser figure at base resolution
To start
File: Export: Wavefront OBJ
Select none in the pop up scene Hierarchy and then check the topmost indicator for the figure. This will select all of the actors that comprise the figure and nothing else...
Use these settings in the export dialogue if you wish to maintain body part groups and materials...
Export to a location of your choice and give the model a unique name.
Next comes the welding bit. You might have noticed that there is a Weld body part seams option. I prefer the results of an import weld.
File: Import: Wavefront OBJ and select your exported model
Check this option, Weld identical vertices, for the import
You may want to hide or delete the original figure. You now have a welded prop of the figure in scene... polygon groups (if you have chosen), material regions and names, and UVs are intact...
Here are the welded props groups and materials demonstrated
Now export your prop again overwriting your initial export so that you can have the welded model external for further use in other software. Again if you want mats and groups maintained overwrite with these options checked...
Here is the welded model in Mudbox, a sculpting software...
Here are it's UVs, UDIM in this case...
The model is suitable for 3d painting (resulting texture painting files suitable for the original figure) and sculpting, here's an aggressive smooth applied to the arms to show that there are no weld splits...
You can also create more elaborate figure props which include clothing and hair models merged with the figure.
Tekitoumen ( ) posted Wed, 20 July 2022 at 11:34 PM
Thank you very much for your kindness.
After doing what I'm doing now, I'll try what you taught me. If you have any questions, I may contact you. If that time comes, I would be very happy if you could tell me again.
Thank you very much.
