Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
I was just wondering about a way to do something like this. Thanks.
Just to add my two cents: I've used this hack to add a controllable glossy effect on some of my Vic4 skins, till I wrote a Python script to do this, and that's the moment when I understood that using a Python script, you can add and name a layer the way you want
Example useable in the Material Room, with the current material:
mat = poser.Scene().CurrentMaterial()
second_layer = mat.CreateLayer('Gloss')
you may even copy and past these two lines in Poser' Python Shell.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I second what Boni said. The majority of Poser users don't do Python scripting or editing files. This is a function that would be a major upgrade to many of us as adding layers for makeup, dirt, blood etc. Is built in for many other similar software. I tried adding layers of such countless times and it requires major fiddling. Older pythons offered this functionality and they are now obsolete, and will never be updated. I would be willing to pay for this, to be honest.
Just to be sure: Boni and Rhia474: are you speaking of what nerd explains, on top? because you don't need python: a simple text editor.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thank you fir the question, Phil, let me try to clarify on my end.
What am saying is: older pythons that did layer adds don't work any more; generic users don't update or edit pythons or any files by opening them in text editors or otherwise, this function should either be built in or an updated Python 3 script that we can buy. I should not need to faff with text editors for adding layers to multiple matzones if this function is described in the manual as existing in the program.
Rhia474 posted at 2:01 PM Mon, 4 April 2022 - #4436722
I understand.Thank you fir the question, Phil, let me try to clarify on my end.
I have a kind of toolbox that I've written for myself. It can add a new layer named 'Gloss' for each skin-related material of the currently selected figure. It recognizes Vic4, La Femme and Aiko3 charactes.
If this interests you, I'd be happy to prepare a standalone script for this.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I have added a lot of paid for scripts my work not really flow only to have them (the scripts) wrecked in a new paid for release only to see the "fix" offered as a NEW PRODUCT I'm tired of this shit break stuff again I'll reinstall Poser 7 or 8 and never buy anything from these sites again you are motivating boycotts. I would accept the warning whole systems cost less than one Graphics Card
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
I don't know if or when the ability to rename layers will be part of the Poser UI. Nor if or when the ability to save a material file with just layers would be added. It's safe to say not tomorrow. If one of the Python gurus make a slick tool to achieve these functions that may be all we need. There are a bunch of layer functions already in Python however the ability to load a material onto just a layer isn't available. That's what motivated this hack.
Rhia474 posted at 5:23 PM Mon, 4 April 2022 - #4436729
You can download the Python script here.I would love to give it a whirl, yes! Thank you!
How to use:
1. open up Poser12's Material Room^
2. select your character (Vic4, Aiko3, LF/LH or one Erorgenesis' Evogirls)
3. be sure that one of the character's part is selected, or the body itself
4. run
the script will ask you the name of the layer, if you want to remove any supplemental layer, and if you want the Gloss setup I'm using
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thank you, Super-nerd.
As you imply --"~1000 lines"-- skinny-dipping huge text-files spawned by eg OBJ or MC6 is not for the faint-hearted, but at least they are plain-text !!
And, yes, unlike some 'text' formats, tolerate editing... { Have you ever tried to fix bad paths in an 'ascii' FBX ? TSB,NFC !! }
Plus, this hack puts a new perspective on MC6: I've copy/pasted the rudiments of such out to MTL, I'm a tad wiser now...
You've probably wanted to add an effect to a material without re-doing the base material. Things like adding makeup or a tattoo. The problem was that saved MC6 materials always replace the existing base material. SuperFly supports layered materials but there's no way to just add a layer to a material from the library ... or there wasn't. With a minor hack of an MC6 that has a layer you can craft a material that will load a layer and leave the base material alone. You can add makeup, dirt, whatever you want to an existing material and it will just overlay the existing material. Just like layers in Photoshop ... well kind of anyway.
WHAT YOU NEED
* Poser 12, latest version
* An MC6 file saved with material layers in it (we'll make this)
* Something to edit Poser files. Poser File Editor or a Text Editor (Not Word!)
FIRST A LITTLE BIT ABOUT LAYERS
Material Layers in Poser are nothing new. They've been around since Poser 11. They were implemented for exactly this usage. What wasn't implemented was a way to save just a layer and add that layer to an existing base material. That's the object of this hack. To make an MC6 material that's just a layer so Poser can add it to an existing material.
Poser's material layers are always replace layers, like a "normal" layer in a paint program. They are also completely opaque by default. The first thing you'll need for your layer is a transparency map. We'll call this a “key map” from here on out because it works like a luminance key in video editing.
OK LET'S MAKE A MATERIAL LAYER
Use Poser's UI to create a material layer by clicking the [+] button next to the layers drop down list. Use the “key map” to setup the area of the material you want to be affected by the layer. Remember the key map is just like a transparency map but it only affects the layer instead of the whole material. An example would be for lipstick. You'll need a key map of the lips so only the lips are visible on the layer.
SAVE THE MC6
Choose only the material zone(s) affected by the material layer. Limiting the file to only the affected materials makes editing the file much easier and prevents the material from potentially messing up unrelated materials.
HACKING THE MC6
This is an easy hack you only need to delete some lines to make this in to a material layer MC6. Find the “Material” line in the MC6 file. Start right below the opening bracket for the material. Delete everything down to the materialLayer line.
You should end up with something like this ...
The “materialLayer” section starts just after the opening brackets of the “material” section. You will need to repeat this for each material included in the MC6 file. Save your new MC6 Layer Material with a new name.
USING MC6 LAYER MATERIALS
Select any part of the figure or prop this material is meant for. Double click the material in the library or drag it to the figure. When loaded the MC6 Layer Mat will add a layer to the affected material zones. Every time you add a MC6 a new layer will be created at the top of the stack. You do not need to manually add layers. They will be added automatically when the MC6 is loaded.
To remove a layer select it from the Drop down list on the material editor. Then click the [-] minus button to remove the layer from that material zone.
FAQ
Q: Why, when I add layers, why do my character's eyes bug out or the clothes vanish.
A: The preview of layered materials is very dependent on the graphics hardware and camera settings. This z-buffer issue only affects preview. The renders will not have z-buffer issues like the preview. You can improve preview quality by adjusting the Hither and Yon values in the the camera.
Q: Can I apply a different base after adding material layers?
A: No, replacing the base material will remove the layers. You can however safely edit the base layer in the Material Edit tab. Material copied with the Assign tab will include all layers.
Q: Can I create effects layers like glowing tattoos or metallic patches.
A: Yes, use the “key map” like you would a transparency on the effects you want. Connect the key to the ambient value or metallic inputs of the shader so they only affect the part of the render your want.
Q: Can I rename the layers? Like “Lips” or “Scar”
A: Yes. This is part of the hack in the MC6 file. Edit the line “name Layer_1” to have the name you want. For example “name Scar”. That will become the display name for the layer inside Poser.
Q: Can I rearrange the layers in Poser
A: No the layers are fixed in the order they are created. Perhaps in a future version of Poser.
Edited because I can't spell.
