Wed, Jan 29, 1:51 PM CST
Forum Moderators: Staff
Subject: Reinstalled Poser - No more Saving/Deletion possible
Robert_Ripley ( ) posted Thu, 21 July 2022 at 3:39 PM · edited Fri, 24 January 2025 at 4:23 PM
I´ve installed it after I got a new PC...(maybe I did not made the best work in saving my libraries and stuff). But after I´ve reinstalled it I just copied my folder into the new one.
And it worked...I could use the stuff I´ve had.
And thats the Problem:
I can´t save materials or delete it. Funny: I can install props and stuff. But materials...no way.
I always get the message when I try to save materials "Warning: Cannot open (Path/Poser11....)"
When I delete something it asks me "really?" and click ok. But nothing happens...the deleted material still there.
I need help :(
NikKelly ( ) posted Sat, 23 July 2022 at 7:23 AM
Have you tried setting the library to 'deep search' ?
Also, Windows can be weird when you copy stuff: I've often found folder 'attributes' set to eg 'write protected'. Worse, may take several attempts to 'un-protect'...
In one case, I had to create a new folder, copy stuff from the intransigent whatsit. Finally, with all contents removed, I could clear the protected flag, delete that folder, re-name its replacement...
