Thu, Jan 23, 12:39 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 21 6:51 am)
banner
Subject: Is possible rendering shadow over background picture?
helderres ( ) posted Sat, 17 September 2022 at 6:27 PM · edited Thu, 23 January 2025 at 3:36 AM
I'm using Poser 11 and whenever I use the picture background, when rendering, I have to hide the ground, but doing so, the shadows of the character or object do not appear on the background picture and at the end, I have to use Photoshop to create the shadow over the background picture.
So I'd like to know if it's possible to render the shadow of a character or an object over the Picture background.
Thank You.
hborre ( ) posted Sat, 17 September 2022 at 7:35 PM
It is possible.  What you need to do is hide the Ground prop and use a square ground plate as your surface.  The plate can be found in the Props Primitive folder.  Select the ground plate and enter the material room, open the Wacro panel on the right and click Set up Shadow Catcher (Yellow Highlight).  Clicking the button will activate the Shadow_Catch_Only (Red Highlight) check box on the PoserSurface.  Set both Diffuse_Color and Specular_Color to black (Green Highlight),
Make sure that the figure/object is positioned on the ground plate and the ground plate placed in its final position.  I recommend that the Cast shadows and Light emitter features for the ground plate be turned off.  Position your light accordingly and tweak the settings so the shadows match the background image.  Assuming that you are using the Firefly render engine, you should have an image that is posted below:
primorge ( ) posted Sat, 17 September 2022 at 8:01 PM
OT but I like that image hborre. It's intriguing. Obviously not deliberately meant to be mysterious but has a nice surreal feel to it. 👍
hborre ( ) posted Sat, 17 September 2022 at 9:23 PM
Thank you.  It was just a quick throw-together render, but I'm glad you like it.
Boni ( ) posted Sat, 17 September 2022 at 10:15 PM
I believe that feature only works in firefly renders.
Boni
helderres ( ) posted Sun, 18 September 2022 at 4:33 AM
I wish to thanks to everybody for this important help.
One more time I learn many important things.
helderres ( ) posted Sun, 18 September 2022 at 5:12 AM · edited Sun, 18 September 2022 at 5:12 AM
hborre, unfortunately I couldn't. I tried to follow your tutorial, step by step, as you can see by the sequence of images I'm sending, but in the end, the shadow did not appear in the background picture.
t8BUnC0FaGFgPcbJTN4fbVEB1dE6SknvAFVYrf8u.JPGma0Nz97V57aV29sSorNZH26nPnmohFKcujDBPPzw.JPG
Can you watch these images and tell me what I did wrong???
helderres ( ) posted Sun, 18 September 2022 at 6:05 AM
hborre
I finally made it.
Your tutorial was absolutely correct.
Y-Phil ( ) posted Sun, 18 September 2022 at 8:17 AM
Boni posted at 10:15 PM Sat, 17 September 2022 - #4444689
Indeed except: either use Poser12's Superfly or, if I'm not wrong: Snarly's EZDome, which has a shadow catching system that works also with Poser11's Superfly
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
helderres ( ) posted Sun, 18 September 2022 at 12:44 PM
Dear hborre and Boni  I created an image dedicated to you, who helped me to render shadow over background picture using Poser 11.
The image is in my gallgia with the thanks to you.
Y-Phil ( ) posted Sun, 18 September 2022 at 2:15 PM
helderres posted at 12:44 PM Sun, 18 September 2022 - #4444713
Beautiful one
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
