Sat, Jan 4, 5:36 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Is it possible to read/update the Natural Value of a parameter?
Y-Phil ( ) posted Tue, 18 October 2022 at 12:43 PM ยท edited Thu, 02 January 2025 at 8:59 AM
Using Python script, one can read and update the driven value (the upper one)
And I wonder if/how we could manage the lower one, called the Natural Value?
This is all the more surprising since we can read and set the min and max values as well as the sensibility, such as in:
Did I miss a method?
Thank you in advance.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
adp001 ( ) posted Tue, 18 October 2022 at 5:54 PM
Try <actor>.<parameter>.UnaffectedValue()
Y-Phil ( ) posted Wed, 19 October 2022 at 5:30 AM
Thank you. Indeed, using UnaffectedValue() I can read the value. I thought that it was also easy to change that value, as in the Parameter Settings popup.
I'll ask the support, as it could beย  more difficult that it looks like, such as following the Value Operations list as show in the Dependencies editor.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
