Wed, Nov 20, 6:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Subject: rendering questions.
mr_red ( ) posted Thu, 10 November 2022 at 11:41 PM · edited Wed, 20 November 2024 at 6:18 AM
4s3PKicAFAwyxY1gvPOnt5poJqmG5KWFjVBw6O4H.jpgcould someone tell me why i keep getting this white disk over the eyes when i render please? this is done in firefly when i render in superfly it dosenot show but the hair looks wrong.
also how do i stop the hair looking like oil paint?
infinity10 ( ) posted Fri, 11 November 2022 at 2:10 AM
Please take a snapshot of your material shader settings for the iris material, so we can see what the current settings are. Looks likesome adjustment required.
Also, the SSS settings for the hair need to be reduced to avoid the spotty look.
Finally, what type of lighting are you using for your Superfly rendering? Not all Firefly lighting works for Superfly.
Eternal Hobbyist
infinity10 ( ) posted Fri, 11 November 2022 at 2:11 AM
The inner parts of the mouth are illuminated, so I think there is some problem with the Firefly shaders when rendering using Superfly.
Eternal Hobbyist
mr_red ( ) posted Fri, 11 November 2022 at 5:21 AM · edited Fri, 11 November 2022 at 5:21 AM
QBBL2VMA3ywwkpXWlzzgk0iMt3nY3RltZ8PgVZwG.jpgsorry its a bit small i had to enlarge it as when i snapshot i get my lower monitor too. anyway now you have pointed me in the right direction and my old brain has kicked it, im thinking the problem is something to do with translucence value?. i turned off all the background as this is for my comicbook and i want to drop my own background behind it.
hborre ( ) posted Fri, 11 November 2022 at 7:51 AM
How close to reality do you want your comic book?  There are shader arrangements that do not work in Superfly.  From what I see of the iris, it needs corrective measures.
mr_red ( ) posted Fri, 11 November 2022 at 9:09 AM
im not over fussy, i want all my fairy's to have yellow eyes so i used v4wild eyes, not sure if thats a good idea or you just have normal eyes and change the iris colour?.
hborre ( ) posted Fri, 11 November 2022 at 9:52 AM
Depends.  If you don't find the appropriate color through texture maps, you can change it in the Material Room.  There are several approaches to make this work.  You don't want to use texture maps with baked-in specular highlights, they look fake if the surrounding and lighting don't match.
