Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Let's say I want a hat. I enter Hat in the Search and get results. Then I click the Old Search link. Along the righthand column, I go to Software and see which Poser has the most results and click that one. It's usually Poser 7+. Additional filtering can be done from there, like selecting a figure or genre. But if it's an item that won't have too many results, I'll just use the Software dropdown in the default (new) search to select Poser like Rhia474 does.
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
The filters in the marketplace aren't very good, because they are actually just tags the creator needed to specify. In principle you should be able to say, "I have Poser 11, show me any content that will work", but it will only show the ones the creator explicitly said "Poser 11" for. Something from Poser 9 will certainly work, but they might not have checked that box.
It would be pretty useful if there was an option to pick "any Poser" rather than having to specify a specific version, because picking any specific version will filter things out. And if you pick multiple versions, it only shows items tagged for all of them, so that gets you even less.
IIRC, the only 'may not work' between P_12 and prior is anything that invokes Python due version change.
I seem to remember a sorta tutorial on how to edit 'old' python files to 'play nice' with new version...
Um, materials ? I recently loaded a 'classic' model, discovered each of the many materials invoked at least a dozen Superfly Cycles nodes. I made window wider and wider, more kept appearing. In the end, I just deleted all but their very basics. My 'post-middle-aged' eyes could not discern any quality loss...
Hi All,
When shopping on the Renderosity website if I've got Poser 12, if I don't see Poser 12 as an option, which one do I choose? The one closest to it -- like Poser 11?
