Poser - OFFICIAL F.A.Q (Last Updated: 2024 Jul 08 1:15 pm)
It looks like this one outlines the old .phi file figurebuild process: http://www.faeriewylde.com/tutorials/WingTut.html
The old PHI Builder program is available here: https://ia601203.us.archive.org/view_archive.php?archive=/20/items/various_cd-rom_iso_collection_2016_07/Infomagic%20-%20Windows%206-Pak%20%28Disc%202%20of%206%29.iso&file=3D-Graphics-Editors.html
1. Export both parts of your helmet seperately as object files.
(Make sure to choose the correct import/export scale. I import stuff from Poser into Wings3D using 20.0 and export using 0.05)
2. Import the two objects into Poser one by one.
3. Open the Hierarchy Editor.
4. Rename the lower part "Body".
Make the upper part a child of the Body. (Simply pull the name of the upper part over the "Body" in the Hierarchy Editor.)
5. Select the Body (!) and click "Create Figure" in the Hierarchy Editor. Select a name.
6. Open a new scene.
7. Load the new figure that Poser created from the "New Figure" folder of your Poser root library.
8. As your figure is supposed to be a hard-shelled object that does not deform, select both figure parts and disable "Bend".
9. Open the Joint Editor and edit the center of the moveable upper part, so that it will properly "open" if you dial xRotate. (You can also rename xRotate to "open" afterwards)
10. Add textures and safe your finished helmet figure once again to a library of your choice.
Nice work rokket. :)
"Dream like you'll live forever. Live like you'll die tomorrow."
I am trying to rig this helmet to open, basically just X rotate. I can get it into Poser, group it by the materials, and create 3 separate props. The problem comes when I attempt to create a new figure from the hierarchy tab. The created figure is all one prop, and dial spinning deforms it instead of opening like I want it to.
So I am looking for a decent tutorial. The one I found was a Poser tutorial that shows using the setup room and creating bones. I am pretty sure that there is an easier way. I had a really good tutorial on my old computer, but it's gone now. I don't remember who made it or where I found it. It was back when I was still using Poser 9.
Anyone know of a good tutorial that doesn't involve going into the setup room? I will if I have to, but I'd rather not have to go that route.
Here is the helmet. I Y-translated the top to show that it is two parts.
