Thu, Nov 21, 3:01 PM CST
Subject: Keeping two versions of Poser
weculativism ( ) posted Tue, 24 January 2023 at 3:21 PM · edited Thu, 21 November 2024 at 2:59 PM
Can I still keep my Poser 11 if I upgrade to Poser 12? Can I run the two versions side-by-side on the same machine? I would like to get Poser 12 but I don't want lose the specific features of Poser 11 like the Face Room and older Python.
Rhia474 ( ) posted Tue, 24 January 2023 at 3:27 PM
Yes. I have P12, P11 and P2014 on same computer.
The one issue may be when you try to open a scene made with later version in an earlier program, outside of that it works just fine.
weculativism ( ) posted Tue, 24 January 2023 at 3:31 PM
Thanks! Excellent news!
Richard60 ( ) posted Tue, 24 January 2023 at 3:52 PM
While you can run two or more versions at the same time do not try to render at the same time as it will cause a conflict between resources.  Also if you use the Queue Manager be aware that they only work with a specific version of Poser and you have to use the Exit option to fully shut it down.  Just clicking the Upper X makes it disappear however it is still running and if you run Poser 11 QM then work with Poser 12 it will give weird results.
hborre ( ) posted Tue, 24 January 2023 at 4:32 PM
Just allow them to install into their own default folders.
weculativism ( ) posted Tue, 24 January 2023 at 5:39 PM
Thanks. This is all good information.
Afrodite-Ohki ( ) posted Wed, 25 January 2023 at 2:46 PM
Online Now!
Richard60 posted at 3:52 PM Tue, 24 January 2023 - #4454567
I've been successful - many times - on rendering in P11 on CPU while rendering in P12 in GPU/Optix. :) can be done if you have two separate resources.
Feel free to call me Ohki!
