Tue, Jan 21, 11:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Fusion of multiple Poser installations
martial ( ) posted Tue, 24 January 2023 at 4:31 PM · edited Tue, 21 January 2025 at 9:46 PM
Allo
On my system win11 i have an HD with multiple installations of Poser : Poser 4, 5, 6. 7,11.12 , Poser pro 2012 and Poser pro 2014. I want  to group all the contents inside Poser 11 and 12 : can i just copy the runtime folder of all versions P4.P5 etc inside the folders of Poser 12.
I am now using primary DAZStudio but i import some stuff from Poser  .And i am using some Poser content  with Vue infinite.
Poser13 ? maybe
hborre ( ) posted Tue, 24 January 2023 at 5:05 PM
That is a great way to completely break Poser 11/12.  Content runtimes can be merged, although, if you try to load old scenes you might get textures missing errors.  Also, most older Python Scripts will not work in P12.
Richard60 ( ) posted Tue, 24 January 2023 at 8:29 PM · edited Tue, 24 January 2023 at 8:31 PM
Bondware refactored the legacy content so it is not in the same location as prior versions <11.3.  So if you did dump the runtimes together you would end up with duplicates.  Also if you are going to do it start with the newest Runtime first and work backwards.  That way you have all the latest stuff and when you put in the earlier version using COPY windows will say there are X number of duplicates and give you the option to skip them which is best as you do not want to replace newer files with older ones.  You are still going to have duplicates due to refactoring but can cull them out afterwards.  This should be done in a folder to be added to Poser 11 or 12 and not the main one.
martial ( ) posted Wed, 25 January 2023 at 4:27 AM
Thanks for your comments More complicate that i thought
