Forum Moderators: Lobo3433 Forum Coordinators: bwsupport
Blender F.A.Q (Last Updated: 2025 Feb 17 11:37 pm)
There are currently not many Poser to Blender tutorials that use the current version of Blender but Tony Vilters has some older ones that are still usable on Youtube https://www.youtube.com/@tonyvilters5822/videos They should work for the most part and give you a basic workflow that you can follow. I hope they help
Lobo3433
Thanks. I'm not into weight mapping yet. Last time I was making figures from scratch I started with hand editing object groups into obj files, and then cr2 hacking.
I'm just trying to replace Lightwave with Blender.
Lightwave used to have this awesome feature called "Conform to Background" that let me cut a head in half without working about the polygon order and then once I had the poly's where I wanted, I could make an original head with the correct poly order conform an to the background layer by proximity to the points. Then when I exported back no exploding polygon heads.
I feel like Dr. Strange having to learn all new spells,
Lobo3433 posted at 12:07 PM Tue, 31 January 2023 - #4455097
mo·nop·o·ly [muh-nop-uh-lee]
noun, plural mo·nop·o·lies.
1. exclusive control of a commodity or service in a particular market,
or a control that makes possible the manipulation of prices
I hope you have success with the workflow I have never tried making morphs for charaters I mostly am into making props dealing with creating things for characters is currently out of my league. good luck :thumbsup:
Lobo3433
Still working on workflow. It seems that Blender's OBJ implementation doesn't support object group as vector goups, which makes it a nightmare to join or recognize body part from obj import.
Joe@HFG posted at 4:01 PM Tue, 28 February 2023 - #4457251
OK think I figured out want to have all the body parts maintain their vector groups which in Blender will be Vertex Groups when you export from Poser when you get to the export options make sure all the follow boxes are checkedStill working on workflow. It seems that Blender's OBJ implementation doesn't support object group as vector goups, which makes it a nightmare to join or recognize body part from obj import.
Then when importing into Blender on the import options you need to change default split option under geometry to Keep Ver Order and put a checkmark in Poly Groups and then all the poly groups do show in the Vertex Groups see last screen shot. I still think there is a cleaner way to do it but have not found it yet but I hope this helps
Lobo3433
Tiny posted at 10:27 AM Tue, 28 February 2023 - #4457193
Sometimes issues with not being able to start a thread you might need to clear your internet cache and which browsers have you tried creating a thread with and if clearing cache does not help send me a site mail directly and I will let the admins know about your issuePlease forgive me for hijacking this thread but for some reason I can't start a new thread. Please advice anyone.
Lobo3433
Lobo3433 posted at 11:05 PM Tue, 28 February 2023 - #4457288
Thank you Lobo3433. The issue for me is when creating a new thread I don't get "Blender" as an option for which forum to post in. It's been awhile so I'm sure I'm missing something obvious. :)Tiny posted at 10:27 AM Tue, 28 February 2023 - #4457193
To allow the Blender forum to show, click on your name in the top right corner and click on settings. There will be a menu bar that starts with My Settings. In that click on forums and scroll down until you see Blender. Check that and scroll back up and hit the save changes button. You should see it when you go back to the forums.
Brilliant! Thank you ever so much it works now. > Happy dance <To allow the Blender forum to show, click on your name in the top right corner and click on settings. There will be a menu bar that starts with My Settings. In that click on forums and scroll down until you see Blender. Check that and scroll back up and hit the save changes button. You should see it when you go back to the forums.
Glad it works now
I'm looking for some help on a workflow for make morph targets for Poser 11 in Blender.
My searches of "Poser Blender morph" have returned nothing I can follow.
