Thu, Nov 21, 3:01 PM CST
Renderosity Forums / Virtual World Dynamics
Welcome to the Virtual World Dynamics Forum
Virtual World Dynamics F.A.Q (Last Updated: 2024 Nov 05 5:09 pm)
Subject: Changing frame rate in Daz
fuqol217 ( ) posted Fri, 20 May 2022 at 11:49 AM · edited Fri, 15 November 2024 at 5:19 PM
Hi
Things seem quiet on the VWD forum - I'm still using it and liking it a lot!
However, one thing I like to do in Daz is create an animation at a low frame rate and then increase it before rendering. This worked with Version 1 Cloth and Hair using Philemot's Daz bridge, but version 2 freezes or goes into an infinite loop. Is there a workaround to allow a change of frame rate? If I have to create the VWD simulation at 60fps it takes a long time, and doesn't seems as realistic as creating at lower frame rates.
Many thanks!
fuqol217 ( ) posted Sun, 12 February 2023 at 6:09 AM
In case anyone else is remotely interested (!), I found an answer to my own question. It is a fair bit of work...
- You can export the VWD animated item from Daz  (base resolution) as both an obj (first frame) and an mdd (lightwave) animation and import those to Blender.
- Then export from Blender as an obj animation. (Select the options to keep vertex order and don't split)
- Import the first frame obj back into Daz and use Morph Loader Pro to create one morph per frame on it for the animation.
- Use the AniMorph script to set the Morphs so only the correct one is at 100% for each frame.
I got this process from Jay Versluis' youtube guide, which has much better explanation: How to import OBJ Sequences into DAZ Studio with animMorph - YouTube
I guess the end result is similar to Philemot's Daz bridge used with v1 of VWD.
I intend to reduce the frame rate when exporting to and from Blender, which should result in a smoother simulation, and smaller file size. When finished I would change keyframe interpolation to linear on all the new morphs, and increase the frame rate.
The downside is that it creates a big scene file when saved in Daz. Also, AniMorph seems to create keyframes on everything on every frame which shouldn't be necessary.
