Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 19 2:31 am)
You can export an fbx, but anytime you got new content for it, you would have to export that tooCan you export clad figure from DS as FBX, import that ??
I'm still hoping a Poser Guru will find a reliable work-path to export a DS figure as OBJ then dynamically drape that onto a morphed Poser 'carrier'...
"You can export an fbx, but anytime you got new content for it, you would have to export that too..."
Thank you.
Um, sounds similar to porting XPS / SFM / PMX to Poser: Provided FBX's sub-rig count stays in single figures, good to go...
FWIW, I've a menagerie of free DS figure packs from #_5~~7, such as Kalea_7, I'll see how that goes...
Sorry, text tad terse as 'Duty Cat' is enthusiastically sub-editing,,,
After trying far too many DS export menu 'differs', I've managed to get Kalea Rogue (a #7) into FBX format (FBX_2012) that Poser likes.
Figure is rigged, clothes 'conform', textures auto-load, may be posed within wary limits using first sub-rig.
But...
1) Export from DS may take a long, long time.
2) Clad #7 figure's FBX is ~90 MB, later #8 and #9 may go through 100 MB...
3) FBX may take a long, long time to load but, happily, at 100% default...
4) Poser does not seem to like complex FBX files and/or texture calls, may become unstable and crash. So, be sure to save scene often....
Has anyone come up with a way to import genesis 9 figures from DAZ into Poser? I use the Genesis 8 import frequently and it looks like G9 will replace G8 soon.
