Sat, Feb 8, 10:19 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Genesis 2 in Carrara
ProPose001 ( ) posted Fri, 24 February 2023 at 6:24 AM · edited Sat, 08 February 2025 at 10:18 AM
This is My Genesis 2 Female.  Character shape and pose is from the 'Art Nouveau Fun Kit' by Canary3d.  The Set and Lights from PhilW's Portrait Studio.  The base figure is a merge of  G2F and 3feetwolf's New Gens, all put together in DS4.10.  the Hair is from AprilYSH.  This is a native Carrara render
WendyLuvsCatz ( ) posted Fri, 24 February 2023 at 6:01 PM
ProPose001 ( ) posted Fri, 24 February 2023 at 9:19 PM
I wish!!!  I've tried but without success.  Maybe Jonstark can wip something up
ProPose001 ( ) posted Fri, 24 February 2023 at 9:36 PM · edited Fri, 24 February 2023 at 9:44 PM
I've also been exploring other options like 'Card' style pubes similar to what's used on the G9 card brows.  A lot lighter on system resources.  There's at least one PA that uses that type of method,  'HerYun' I believe uses that on a couple of his/her products.  I'm still experimenting.
ProPose001 ( ) posted Fri, 07 July 2023 at 3:52 AM · edited Fri, 07 July 2023 at 3:52 AM
Here's an example of G9 Card 06 Brows on G2F
ProPose001 ( ) posted Fri, 07 July 2023 at 3:56 AM
I didn't merge the brows into the G2F figure, and as a result, the Brow dials in the Actor node respond properly, but the Brow dials in the Root node do nothing.
ProPose001 ( ) posted Sun, 17 September 2023 at 8:05 PM · edited Sun, 17 September 2023 at 8:05 PM
Still stuck on G2F
This is Quinn by Saiyaness For G2F.  The light set I used here is by PhilW from his Portrait Studio kit for Carrara.  Anyways, I'm playing around with an 8k texture set for G2F I found online.
ProPose001 ( ) posted Thu, 19 October 2023 at 3:31 AM · edited Thu, 19 October 2023 at 3:31 AM
Another example of 8k skin textures on G2F
ProPose001 ( ) posted Fri, 20 October 2023 at 10:08 PM · edited Fri, 20 October 2023 at 10:08 PM
For the next few images, Same G2F, same skin, same Layton Hair, but different scene.  I started this exercise after watching a utube video by Jay featuring Colm Jackson talking about Rembrandt lighting.  That's what the above image was supposed to illustrate, but I mangled it completely cause I moved some of the lights around and adjusted the levels.  In the video, they are using Daz Studio with Iray,  and the results are awesome with the Render Studio light setup by Colm.   So after butchering my initial attempt, (the image above) using the Render Studio light set, I started fresh using Phil's Portrait Studio (Carrara content) instead.  This is what I came up with so far.
Face Camera
Upper Body Camera
