Blender F.A.Q (Last Updated: 2025 Jan 04 10:38 pm)
Which version of Poser are you exporting from? Also which version of Blender are you importing to? That looks like the old Millennium Horse originally from Daz studio that you could install into Poser some time back. I know that FBX imports into Blender are usually very troublesome I started using an add-on that you can find on the Blender Market called Better Fbx Importer & Exporter that seems to resolve most FBX import issues just using their default settings. I can not place a link to the add-on since Blender Market is another market place but I am sure you can look it up. Also depending on which version of Poser you are using the Poser Manual has some recommendations on how export from Poser and which settings are most optimal to work with other 3D software in general. Poser12 Reference Manual
I hope this helps
Lobo3433
OK I tested with the old Millennium Horse and got similar results as you were getting with default standard Blender 3.4 also and just for kicks tried it in Blender 2.93 and got the same deformations used the Better Fbx Importer & Exporter add-on with it's default saetting and it imported normally good luck :thumbsup:Thank you Lobo3433. I am using Poser 12 latest patch, Blender 3.4. Horse is the Hive Wire horse. I will find the Better Fbx and test it. Good advice. 😊
Lobo3433
Is it possible to export a character, horse in this case, in fbx format from Poser to Blender without it ending up in a bundle? See pic below.
I have tried all kinds of settings but with same result. Is it even possible? And if it is possible will it keep morphs and animations?
Any help and suggestions much appreciated.
