Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 03 10:43 am)
Isn't that effect a preview window setting?
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Thanks for the reply. Will it preview looking like that, pre-render? What I need is to be able to see what the sillouhette will look like while I am posing it, not just once it is rendered.Delete everything from the startup scene if it has anything in it (lights too!), hide ground (Ctrl+G), load figure, pose, render. It will render like that.
I don't know if this still works but in Poser 11 - and earlier versions - you can add lights to the scene that won't illuminate the render, but will illuminate the scene for posing stuff. I've used them quite a lot in low light scenes.
Here's a nice trick that I've probably read here, on Rendo's forums, long ago.
My poses lights is a set of 3 infinite lights, without shadow, and setup this way:
Permanently lighting up the scene in the Poses room, non-existent at render time
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
That's exactly what I meant. Nice one, Y-Phil.
mrjayjayjay posted at 8:02 PM Sat, 18 March 2023 - #4459007
Rhia474 posted at 9:54 PM Thu, 16 March 2023 - #4458789I don't know P11 but P12 has a document style for that, called "Silhouette" (CTRL+1), maybe it helps you too, in the example below you see the preview window with the ground hidden:Thanks for the reply. Will it preview looking like that, pre-render? What I need is to be able to see what the sillouhette will look like while I am posing it, not just once it is rendered.Delete everything from the startup scene if it has anything in it (lights too!), hide ground (Ctrl+G), load figure, pose, render. It will render like that.
Like I said earliermrjayjayjay posted at 8:02 PM Sat, 18 March 2023 - #4459007
Charles Péguy
Hi all.
I'm relatively new to Poser and wanted to ask for some advice. I'd like to be able to pose and render out still images of figures as black sillouhettes on a flat background. Is there a fairly straightforward way to do this please?
