Fri, Jan 10, 10:06 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: GUI Close Handler for wxPython and poserPython
gbn ( ) posted Wed, 05 April 2023 at 3:34 PM · edited Fri, 10 January 2025 at 6:19 AM
Hello, I'm porting my Tkinter-script to wxPython and using wxFormBuilder as GUI builder.
The GUI script is running well on Poser Pro 11. I used the HelloWorld-example (Not Standalone) from PhilC's book "Python for Poser 8" as template.
But implementing the close of the GUI in a controlled way, currently I use just the Close-button of the AUI-pane w/o any syncronization, is from my humble view harder than expected.
The easiest way to write self.Destroy() inside MyApp::ButQuitFunc() and deactivation of Close-button of the AUI-Pane followed to a hangup in the script and crash of P11pro.
Contacting the pane-object, which might be useful, inside class MyApp is not so easy since its commands are in the main-part of the script after the class-definition.
I tried out several proposals of chatGPT for adding  class-methods OnInit() and OnClose(), but failed.
Has anyone maybe PhilC ;-) an idea to solve my problem ? TIA /Gunnar
mport wx
import wx.aui
import poser
import os
import sys
sys.path.append(r"D:\Users\public\Documents\PoserPython\wxFormBuilder\RJB")
from RJB_gui import *
sys.path.append(r"D:\Users\public\Documents\PoserPython")
from WxAddOn import *
man = poser.WxAuiManager()
root = man.GetManagedWindow()
scene=poser.Scene()
PU = 262.128
class MyApp(MyMainPanel):
def __init__(self, root) :
MyMainPanel.__init__(self, root)
self.root = root
self.Show()
# Virtual event handlers, override them in your derived class
def ButNewFunc( self, event ):
print "New!"
def ButLoadFunc( self, event ):
print "Load!"
def ButSaveFunc( self, event ):
print "Save!"
def ButShowFunc( self, event ):
print "Show!"
def ButAddFunc( self, event ):
print "Add!"
def ButInsertFunc( self, event ):
print "Insert!"
def ButDeleteFunc( self, event ):
print "Delete!"
def ButUpdateFunc( self, event ):
print "Update!"
def ButRenderFunc( self, event ):
print "Render!"
def ButPreviewFunc( self, event ):
print "Preview!"
def ButCamResFunc( self, event ):
print "CamRes!"
def ButCamSizeFunc( self, event ):
print "CamSize!"
def ButPOVFunc( self, event ):
print "POV!"
def ButSizeHgtFunc( self, event ):
print "SizeMgt!"
def ButQuitFunc( self, event ):
print "Quit!"
app = MyApp(root)
man.AddPane(app, wx.aui.AuiPaneInfo().
Caption("RJB").CaptionVisible().
Float().Resizable().DestroyOnClose().
FloatingSize(app.GetSize()).CloseButton(True))
info = man.GetPane(app)
info.Show()
man.Update()
adp001 ( ) posted Wed, 05 April 2023 at 4:57 PM
To catch a close-event you have to set up a corresponding handler using "Bind":
                self.Bind(wx.EVT_WINDOW_DESTROY, self.myCloseHandler)
gbn ( ) posted Fri, 07 April 2023 at 2:44 PM
THX, works. Now it closes always. Trying to make it optionally.
