Sat, Feb 1, 4:37 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 31 3:19 pm)
Subject: Material/Textures from Included Folder broken...
blackbonner ( ) posted Fri, 07 April 2023 at 7:33 AM ยท edited Sat, 01 February 2025 at 10:40 AM
Hi fellows, I just tested something inside the material room and tried to use the LaFemme textures. They render just fine, but they are not showing up in the preview. The whole figure is gray. I checked the preview mode, used Poser 12 LaFemme textures who get recognize by the preview. This might be a bug, because it only happens to the materials in the new Included Folder of Poser 13.
DCArt ( ) posted Fri, 07 April 2023 at 7:47 AM
The shaders aren't broken. They use the Cycles root node, which previews in gray (even in Poser 12). Hoping the preview issue will be fixed in a future P13 release. 8-)
blackbonner ( ) posted Fri, 07 April 2023 at 7:52 AM
Ah, okay! A warning sign seems to be in order, don't you think? I wasn't aware of this fact. Thanks for helping me out!
adp001 ( ) posted Fri, 07 April 2023 at 11:14 AM
DCArt posted at 7:47 AM Fri, 7 April 2023 - #4461095
Apparently, this is not the case with all hardware. On my HP convertible with the relatively simple graphics chip Mesa Intel UHD Graphics (CML GT2), materials based on Cycles Surface are displayed. On my workstation with Radeon graphics card with 8Gig memory, however, they do not (on the exact same PP2). Here is what I see on the HP:
adp001 ( ) posted Fri, 07 April 2023 at 11:21 AM
What comes out as a render, however, does not have much to do with the preview in terms of lighting (HDRI without any other light source):
DCArt ( ) posted Fri, 07 April 2023 at 11:39 AM
Yes it has something to do with hardware shading and OpenGL.ย  I have an RTX-3070 and if I uncheck the "Enable Hardware Shading" option in the Preview tab of render settings, I see the textures. But it seems what that does is show whatever previews in FireFly, so that may also be a bug.
The dev team is aware of this and hopefully will address it in an upcoming release.
Y-Phil ( ) posted Fri, 07 April 2023 at 11:46 AM
DCArt posted at 11:39 AM Fri, 7 April 2023 - #4461134
An upcoming release, but not today's...ย uW2KS2zHun7S5bmDH0tGBL4TOXCoKebNUJZWr30x.gif
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
ChromeStar ( ) posted Fri, 07 April 2023 at 12:44 PM
Disabling hardware shading does cause the preview to fall back on the Firefly root. That's been acknowledged as a bug. Frankly, I think it is better to keep it that way until Cycles gets proper previews. At least it gives you something to work with. It's hard to point eyeballs when they are all white.
Y-Phil ( ) posted Fri, 07 April 2023 at 2:14 PM
Pretty much why most of my materials have both setups: PoserSurface (even a basic one) and Cycles-based, plus a Python script I've added to my toolbox to switch the figure/prop I'm posing back and forth Firefly <-> Superfly
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
blackbonner ( ) posted Fri, 07 April 2023 at 2:21 PM
Well, well, it seems I stumbled into something interesting. I got an Nvidia GTX 1650 GPU and as far as I know open gl is available with it. And I have to say a working preview for any form of shader regardless would make working with Poser much easier.
ChromeStar ( ) posted Fri, 07 April 2023 at 9:47 PM
I don't think it has anything to do with what GPU you have. Cycles shaders are white if you enable hardware shading in the previews, and it will display whatever you've got for Firefly if you disable it (which might lead you to think you're seeing Cycles previews, but you aren't). I treated myself to a 4090 so it's not like my GPU is not up to par.
I know I could just toggle between firefly and superfly to get different previews, but 90% of the time when I do anything as a temporary thing (e.g. add some working lights), I forget to change back before hitting render. :)
blackbonner ( ) posted Sat, 08 April 2023 at 3:23 PM
ChromeStar, I know what you mean. I forget to turn the work lights off most of the time. It happened so often that I searched for an automatic solution and I stumbled across something that was made by BagginsBill. If you create a work light got to the material room, select the light and add a simple color node to the surface color slot. Then set both specular and diffuse color to black. To make a perfect work light, go to it's parameter tab and turn of the shadow. A light with this settings will be ignored by Firefly and Superfly render engine but will illuminate your scene during posing. This is a bit time consuming to set up, but afterwards it saves a lot of time and nerves.
ChromeStar ( ) posted Sat, 08 April 2023 at 11:56 PM
Hmmm, I think you also have to set the simple color's color to black, and then it only works if "enable hardware shading" is unchecked in preview settings. Still, better than I had, thanks!
