Thu, Jan 30, 8:32 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 30 4:26 am)
Subject: Poser 13 render help needed.
Donna68 ( ) posted Thu, 20 April 2023 at 2:52 AM · edited Tue, 28 January 2025 at 11:49 PM
Hi guys need some advice. I have upgraded to poser 13 from poser 12 and I'm having a problem I can't sort.
When rendering a scene using a background picture there is a plain strip either side of the render. I have tried to match background picture size to render size tried different image formats and different size images and nothing is working.  Where am I  going wrong.  Any help appreciated.  Did not have this problem with poser 12.
Thanks in advance.  Donna.🙂
Y-Phil ( ) posted Thu, 20 April 2023 at 9:22 AM
Not sure what you are trying to do but one solution could be to render using the transparent option, and then to assemble the result in any classic picture manipulation program.
If you're going this way: don't forget to hide any surrounding sphere, export it as PNG they keep the transparency
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Donna68 ( ) posted Thu, 20 April 2023 at 12:02 PM
I'm trying to use a sky background image in my render but no matter what render size I set it to, there are still white edges with the sky in the middle of the render.
hborre ( ) posted Thu, 20 April 2023 at 1:27 PM
Online Now!
I would suggest posting a screencap of the problem so we can visualize what is happening.
nerd ( ) posted Thu, 20 April 2023 at 1:34 PM · edited Thu, 20 April 2023 at 1:34 PM
Forum Moderator
Two things may cause this. First is the background picture need's to be set to Auto-Fit. That's in the material room ...
Select the background Object and then check that box.
If you still get bars on the edges the aspect ratio of your scene needs to match the aspect of the background picture. From the top menu choose Render > Render Dimensions. Set at to Render to exact dimension and type in an a size that's the same as the aspect ration as your back ground.
It doesn't need to be the exact size of the background but just the same aspect. So if the original was 4096 x 2048 you can use 2048 x 1024.
The scene preview may still show blanking bars but when you render the image it will render with no blanking bars.
