(Last Updated: 2025 Jan 21 10:36 pm)
I'd open a support case so Tim and co can look it over. You may be required to do a collection and zip it up and send it to them. See below how to go about doing that... You will want the "collectSceneInventory" script..........
When you submit your case you should have an area to upload (drag and drop I think) your zip file to upload to their servers.
---Wolff On The Prowl---
actually, there's an easier way. Under files>export save for sharing collects everything and zips it for you.
But it smells like a memory corruption.
If you would like to launch a good, thorough and reliable memory test, let me suggest you MemTest86+. I suggest that you download an USB version and launch the test outside any operating system.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Hi,
since the last Poser 13 update, I have a very annoying issue. Poser often crashes mid render.
This is what exactly happens:
- I load simple scene, 1 figure, 1 area light
- render (CPU Fast preset) --> ok
- render (CPU Fast preset) --> crash
So rendering the same scene without making any modification renders fine for a few times and then it crashes.
It's not with a specific scene but with seemingly every scene file I tried (used Dawn figure, La Femme)
I also notice that large files are being produced in my Poser/Crashdumps dir (~ 4Gb files with .dmp extension)
I saw on Google that there is something call WinDbg to read .dmp files. I installed it and opened one of the .dmp files with it.
But this is far too techincal for me.
The tool showed:
Any idea what this might be?
Otherwise I'll open a support case
