Thu, Oct 3, 7:32 AM CDT
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2024 Oct 02 4:54 pm)
Subject: updated poser 13 and now render sampling not finishing
rj3504 ( ) posted Thu, 04 May 2023 at 11:49 PM · edited Thu, 03 October 2024 at 7:20 AM
I have had no issues with superfly renders with poser 13  until I updated to the 13.0.296. Now my renders only reach half the samples and  the sample bar speeds to completion, leaving a grainy render. I've used a higher sample count with no success. any advise would be helpful. thanks
RedPhantom ( ) posted Fri, 05 May 2023 at 7:28 AM
Site Admin
Are you using adaptive sampling? You might reduce that or turn it off.
Rhia474 ( ) posted Fri, 05 May 2023 at 7:54 AM
The recent update mussed up adoptive sampling numbers in the presets a bit. All are set too high. Lower sampling rate to something like 0.002, and try again.
Also play around with lights, I fund its a lot more sensitive to light placement and setting.
