Sun, Jan 5, 8:15 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 05 6:44 am)
Subject: Working Scripts?
tastiger ( ) posted Wed, 17 May 2023 at 6:58 PM · edited Fri, 03 January 2025 at 3:20 PM
Is there a list somewhere that has the scripts for Poser 12 that still work in Poser 13?
As there wasn't an upgrade path from Poser 11 to Poser 13, I had to buy Poser 12 and then Poser 13, I doubt I will venture into Poser 12, so no use purchasing scripts that won't work.
Thanks in advance.
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz   3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
Ken1171_Designs ( ) posted Wed, 17 May 2023 at 8:25 PM
Hi Robert.
All the scripts I made for Poser 12 will work fine in 13. Some had to be modified to handle changes in the new Material Room, because the Physical Surface root node has been changed (new "Walk" SSS method and inputs). I believe that's the most noticeable change anybody can see, though there were internal changes as well. But don't worry - my scripts have already been patched, and support the changes introduced in P13. At least on my side, you are covered. :)
Hope this helps,
--=Ken
My Store at Renderosity
My Store at PoserSoftware
Characters, Body Sculpts, Morph Corrections, Outfits, Python Scripts, Universal Heads, and Videogames!
HartyBart ( ) posted Wed, 17 May 2023 at 9:14 PM
So far as I know, everything Python that works for Poser 12 should work for Poser 13. The big change to Python 3 came back in Poser 12.
hornet3d ( ) posted Thu, 18 May 2023 at 2:38 PM
I have a number of Ken1171_Designs kits and I can confirm they all that i have work fine work in Poser 13.
