Sat, Jan 11, 9:42 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Accessing Poser Files Directly
JimX ( ) posted Sun, 11 June 2023 at 10:38 AM · edited Sat, 11 January 2025 at 7:41 AM
I am in Poser, with a particular file selected:
Is there any way to get the path of that file so that I can open tit in a Python script directly, without having to use anything like the FileDialogChooser?
Similarly, with a library chosen like:
Is there any way to open that folder directly (so I can write a file into it), without having to use anything like the FileDirChooser?
FVerbaas ( ) posted Sun, 11 June 2023 at 1:50 PM · edited Sun, 11 June 2023 at 1:50 PM
Forum Coordinator
Unfortunately the library can not be accessed via Python.
EVargas ( ) posted Sun, 11 June 2023 at 3:02 PM
Hi, maybe you could try and "guess it" based on the geometry path?
actor = scene.CurrentActor()
geomPath = actor.GeomFileName()
EVargas.Art
JimX ( ) posted Sun, 11 June 2023 at 3:36 PM
What I was trying to do is manipulate some things in a material (or material collection) file. So the CurrentActor() would actually be a hr2 or pp2 file.
But. you've got a good idea about getting at least a guess as where to start DialogDirChooser: same Runtime as the geomPath, but over in the Materials library.
Y-Phil ( ) posted Mon, 12 June 2023 at 1:39 AM
There's a way using the material that's already loaded, especially if there's a bitmap, but I'm not sure if the Library Window is sufficiently talkative to expose what is actually selected in which tab).
There are many parts I would like  to be exposed, such as the groups in the Property Window, too.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
HartyBart ( ) posted Mon, 12 June 2023 at 3:59 PM
I'm not at all sure what you're trying to do or why. But perhaps the free "Find it - three Python finder scripts for Poser 11" on ShareCG might interest. Not geared for Hairs, but you might hack it to work with them....
"a set of three helpful 'finder' Python scripts for Poser 11. Each script detects and then inspects the current figure in your Poser scene. The chosen script then tries to open Windows Explorer on the correct path for either the figure's .CR2 files, .OBJ files, or the .MATs and/or Poses for that figure."
JimX ( ) posted Mon, 12 June 2023 at 5:44 PM
I'm trying to apply Texture Maps without applying Transparency Maps, and/or apply Transparency Maps without applying Texture Maps. Using Poser 11 on a Mac.
Those scripts sound interesting. I'd like to look into them.
I created an account on ShareCG. But I can't find those three scripts.
HartyBart ( ) posted Tue, 13 June 2023 at 4:39 PM
Search DuckDuckGo for "Find it - three Python finder scripts for Poser 11" (include quote marks) and it's result No.1. I'd link it here, but we're not allowed to link to competitor stores.
But it sounds like what you really want is a script that just disconnects all the transparency map nodes, or disconnects all the other texture map nodes? In which case that's fairly simple. But why would you need to do that?
JimX ( ) posted Wed, 14 June 2023 at 12:28 PM
OK. I'll try that search.
Actually, what I want to do is to REPLACE all the Transparency Nodes, but none of the Texture Nodes. And vice-versa.
Actually, I found a reference in the online Poser documentation that says you can call a script out of a pz2 file. The mt5 and mc6 files have a similar structure, and I tried it with them. It worked. This gives my another set of things to try.
So I've got a couple of avenues to go down. Options are always good.
Many thanks.
HartyBart ( ) posted Wed, 14 June 2023 at 1:42 PM · edited Wed, 14 June 2023 at 1:42 PM
If you want a disconnector script, as an example to tweak, there is one on ShareCG as "Simple Python script to disconnect all bump maps" in a scene. That's for Poser 11. There's also a Poser 12 one called "Python script to disconnect all bump maps - P12".  Useful for rendering speckle-free in Firefly with a 'with cartoon lines only' preset (included). Or before sending the scene to Vue, where the bump mapping just won't be seen on the figures / props amid a huge landscape / atmosphere.
JimX ( ) posted Wed, 14 June 2023 at 2:05 PM
I downloaded the three finder scripts. In the process, I found that they are available right here in the Renderosity Free Stuff.
I can't use the scripts directly, as they depend on Windows-only executables, and I'm on a Mac. But there are some good ideas in the code that might give me some inspiration.
HartyBart ( ) posted Thu, 15 June 2023 at 5:36 PM · edited Thu, 15 June 2023 at 5:37 PM
I forgot they were also on Rendo. Oh well, at least you got onto ShareCG - there are lots of scripts there that are not on here. Great freebies, too.
I'd also forgotten they used Windows .BAT files as an intermediary. Maybe there's a Mac equivalent? .BAT files are just simple text instructions to Windows.
