Fri, Jan 31, 12:05 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 31 6:43 am)
Subject: Black blobs all over my props after rendering
Romeo4755 ( ) posted Tue, 13 June 2023 at 9:33 AM · edited Fri, 31 January 2025 at 12:55 AM
Poser 2014
Hello. I have been studying this problem and I know about polys' self-shadowing and I switched my cameras all to spotlight. Still, I'm sad.
I m guessing the problem may be in my props. I imported clothes made in Marvelous Designers and then IMPORTED AGAIN WITH REVERSED POLYS to be able to see the backside of the garment. Then I export them together as one OBJ and import back, and use them. The rendered image is full of terrible dark spots.
Preview:
Rendered:
I removed textures and everything in Materials Room:
ticked @Remove backfacing polys@ in Render Settings, still the same.I imported a prop once, with no double inverted copy and here is the difference:
Preview
Rendered
I would appreciate any advice on what I can do here.
Romeo4755 ( ) posted Tue, 13 June 2023 at 10:16 AM · edited Tue, 13 June 2023 at 10:17 AM
I just found @Remove backfacing polys@ option in Render Settings - Preview bookmark, and unticked it! Now I don't have to have two-layers props, I hope that has done the trick!
nerd ( ) posted Tue, 13 June 2023 at 1:04 PM
Forum Moderator
The jacket seems to be modeled with 2-sided polygons. The other solution would be to remove the inside polygons in the actual model.
Romeo4755 ( ) posted Tue, 20 June 2023 at 9:16 AM
nerd posted at 1:04 PM Tue, 13 June 2023 - #4467815
Thank you. It's just great to have experience - you look at the picture and understand the problem because it's an already familiar sight.
