Sun, Jan 5, 8:05 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Script help
Uncanny_Film ( ) posted Mon, 21 August 2023 at 10:54 AM · edited Sat, 21 December 2024 at 5:54 PM
Hi, I'm trying to learn code. And I wanted to create a poser script. I tried to make a simple zero transition script. But I got this error message:
Traceback (most recent call last):
  File "C:\Users\spart\Documents\1.py", line 18, in <module>
    set_rotation_axes_to_zero()
  File "C:\Users\spart\Documents\1.py", line 9, in set_rotation_axes_to_zero
    current_selection.SetXRotation(0)
AttributeError: 'poser.ActorType' object has no attribute 'SetXRotation'
What am I doing wrong? Thanks
Here's my code:
import poser
def set_rotation_axes_to_zero():
    # Get the currently selected object in Poser
    current_selection = poser.Scene().CurrentActor() or poser.Scene().CurrentProp()
    if current_selection is not None:
        # Set X, Y, and Z rotations to zero
        current_selection.SetYRotation(0)
        current_selection.SetZRotation(0)
        print("Rotation axes set to zero for the selected object.")
    else:
        print("No object selected.")
# Call the function to set rotation axes to zero
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
HartyBart ( ) posted Tue, 22 August 2023 at 1:21 PM
Here's a 'most simple' script to zero the rotations on the currently selected/active prop or figure, which may be of use.
# Zero the rotation of the currently selected prop or figure in Poser. Works in P11 or P12.
import poser
scene = poser.Scene()
actor = scene.CurrentActor()
actor.ParameterByCode(poser.kParmCodeXROT).SetValue(0.0)
actor.ParameterByCode(poser.kParmCodeYROT).SetValue(0.0)
actor.ParameterByCode(poser.kParmCodeZROT).SetValue(0.0)
# Redraw the OpenGL Preview viewport in Poser, so we can see what's been done.
scene.DrawAll()
Uncanny_Film ( ) posted Wed, 23 August 2023 at 3:13 PM
HartyBart posted at 1:21 PM Tue, 22 August 2023 - #4473228
import poser
scene.DrawAll()
Thanks,
Also, here's a code that I came up with. To set X Tran to 1.
How can I alter this code to change the transitions +1 unit every time I activate this script?
Thanks
import poser
scene.CurrentActor().ParameterByCode(poser.kParmCodeXTRAN).SetValue(1)
scene.DrawAll()
HartyBart ( ) posted Wed, 23 August 2023 at 5:20 PM
Ah, I see. Here it seems you're trying to do a 360-degree spin-around animation on the X axis? We'll there's my paid-for script in the Store, which gets you an animated 360-degree turnaround animation.
But the basic 'increment a value by one' script for Poser would be...
import poser
# Capture the number on the actor's X-rotation dial.
value = actor.ParameterByCode(poser.kParmCodeXROT).Value()
# Take this newly found number and increment it by one.
value += 1
# Now set this new incremented number on the actor's X-rotation dial
actor.ParameterByCode(poser.kParmCodeXROT).SetValue(value)
# Redraw the OpenGL Preview viewport, so we can see what's changed.
scene.DrawAll()
