Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
While you don't need to make a morph or delete the later frames, it can be done. With the clothing selected, under the Object menu choose spawn morph target. That will give you a morph of the drape.
allo
i am using Poser 13 and following some tutorial i have used before for Poser 7 or Poser 11 ,at the end of clothing simulation (here from frame 1 to 30) the cloth prop is correctly posed on the character at the frame 30 . In th old version the last step before was to create a morph and we go then to menu object and spawn objet and applied the morph created to the prop cloth at frame 1 put the morph setting to 1.000, pose the figure and delete the frames from 2 to 30.And save the figure with the cloth prop correctely pose
But in Poser 13 the menu Object has changed and i don't know what i can do for create morph
Is there a new tutorial for Poser 13 for apply dynamic cloth prop to a figue , like La Femme 2
PS i hope my text is ok because i am a french speaking person
