Tue, Nov 19, 7:44 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Getting/Setting Intensity for a light?
OberonRex ( ) posted Mon, 13 November 2023 at 11:50 AM · edited Tue, 19 November 2024 at 7:40 AM
I can write Python code to loop over the lights and tell if they're on or off. I can set them on or off. And I've just failed miserably at finding how to get and set the intensity. Sure looks like "Intensity" is the magic word, but I'm missing something.
For an individual light, I can access light.LightType, LightOn, SetLightOn, SetLightOff, but, sigh, I cannot find how to get/set intensity.
Has to be simple but I can't figure it out.
So -- what's the secret, eh?
OberonRex ( ) posted Mon, 13 November 2023 at 12:17 PM
Nevermind. Naturally, after "giving up" and asking, I found it.
bagginsbill ( ) posted Mon, 13 November 2023 at 12:20 PM
You grab the parameter from the actor and then you can use Value() or SetValue() to read and write it.
OberonRex ( ) posted Mon, 13 November 2023 at 12:43 PM
Thanks!
And also thank you for your footnote about reply notifications. Useful to know.
Bastep ( ) posted Mon, 13 November 2023 at 12:46 PM
Its simple:
# DimLights.py
# Makes the light brighter or darker
# Date:             13.11.2023 19:31:50
# Letzte Aenderung: 13.11.2023 19:31:52
# Author:           Bastep
# Contact:          via Renderocity
# This is free to use.
import poser
def main():
    light = poser.Scene().CurrentActor() # Retrieves the selected Actor from the scene.
    if light.IsLight: # Is the Actor a light?
        intensity = light.Parameter('Intensity') # Retrieves the intensity parameter from the parameter list
        print(intensity.Value()) # Shows the current value
        intensity.SetValue(0.5) # Assigns the new value. The values refer to 1. 1 = 100% intensity
        print(intensity.Value()) # Shows the new value
if __name__ == "__main__":
    main()
