Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
I created a list for GetIdType(...) myself. Is this list complete? Who knows. If I find something new I will add to the list.
Here the list:
ID_TYPE_BODY_ACTOR = 7
ID_TYPE_CAMERA = 8
ID_TYPE_LIGHT = 9
ID_TYPE_PROPS = 12
ID_TYPE_BASE = 16 # Magnet
ID_TYPE_DEFORMER = 18 # Magnet
ID_TYPE_ZONE = 21 # Magnet
ID_TYPE_HAIRPROP = 23 # Only applies to hair done in the Hairroom.
ID_TYPE_IS_CONTROL_PROP = 28
ID_TYPE_GROUPING = 29
ID_TYPE_MEASUREMENT = 34
# The following ID covers various scene objects.
# CenterOfMass
# GoalCenterOfMass
# BackgroundMaterialActor
# AtmosphereMaterialActor
# FocusDistanceControl
ID_TYPE_VARIOUS = 26
Here's what I've been able to determine:
PPM_GETIDTYPE = 'GetIdType'
ActorTypeNames = { 7 : 'actor',
8 : 'camera',
9 : 'light',
12 : 'prop', # IsPropInstance
15 : 'curveProp',
16 : 'baseProp',
18 : 'magnetDeformerProp',
19 : 'waveDeformerProp',
21 : 'sphereZoneProp',
23 : 'hairProp',
24 : 'uniformForceFieldProp',
25 : 'coneForceFieldProp',
26 : 'controlProp',
28 : 'controlHandleProp',
29 : 'groupingObject',
34 : 'measurementLine',
35 : 'measurementAngle',
36 : 'measurementCircle',
37 : 'measurementPolyline',
Not every valid IdType has a defined poser constant, though.
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
Ugh! I've spent too long away from this forum. Can't remember all the formatting settings. [Sigh] ;-)
Yup. I should note that my dict is intended to ease the writing of Poser files. Every low-level object in a Poser scene is an "actor", including cameras, lights, the UNIVERSE actor, props, and, of course figure body parts. Only the "body actors" get the string "actor" in poser files as their TypeId string.
Poser has a long and storied history of using terms which later lead to confusion by varied usage. "Actor" is just one of many, sadly.
Early ideas were built upon, and later features introduced to Poser file syntax which rendered prior naming illogical, though they were initially logical, e.g. targetGeom channels (or morph targets) have an "indexes" attribute. Initially, this was the only attribute before the list of deltas, indicating the length of the list. However, that did not accurately indicate that zero deltas could be omitted, so, instead of repurposing "indexes" to indicate the range of valid indices or the number of vertices in the actor's geometry, a new attribute "numbDeltas" was added to (confusingly) indicate the number of geometry vertices, instead of a count of the number of non-zero deltas present.
Poser is fraught with contradictions due to the avoidance of backward incompatibility.
That, and the absolute absence of complete, detailed, official documentation of the Poser file formats and their syntax has been a hindrance which we struggle to overcome.
Understandable commercial pressures on the string of owners has also prevented this coming to fruition. We are lucky to have had such a supportive community willing to share their discoveries (even speculative) without ever having sighted a single line of code (Though some lists of constants have been known to be shared to help script developers).
In the Poser API, there is the GetIdType() method under the object definition for SceneObjectType. This returns an integer. Is there a list of this ID?
Regards
class SceneObjectType(builtins.object)
Methods defined here:
GetIdType(...)
Return the exact type of this scene object.
<IntType> GetIdType()
