Fri, Jan 3, 3:44 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 02 10:01 am)
Subject: Issues with Poser 13 libraries
Digimon ( ) posted Sat, 18 November 2023 at 7:09 AM · edited Mon, 30 December 2024 at 7:25 PM
Hello!
I have been using Poser since the late 90's earliest version, so I am not a complete newbee. That said, I can't say I have ever understood the file structure completely. Yet, I have over the years, been able to get most things working.
I can't imagine I am the only one that buys some content from DAZ. As you know, DAZ is not Poser friendly, in the sense that I do not see (Now) any Poser installers for their content. As such, we have to install the files ourselves. No problem, right? So I thought...
I have managed to get some of the content I bought, working. So I am not sure why I am having issues with the base 3D universe toons. Here are some pictures to show the file structure for the model files (obj). many of the other files, like the robots and the cat, work fine... but for some reason the base toon (Human) files are not working. They show in the library, but when I click on them, I either get nothing or an error... I will include the error as well.
Thank you in advance for your help! :)
Why isn't it moving?
Digimon ( ) posted Sat, 18 November 2023 at 7:31 AM
Oh, forgot to include the error:
"File "/Applications/Poser 13/Runtime/Libraries/Character/3d universe - toon/Toon Generations/Randomize Generic/Base_Character.py", line 16  if vGeomPath.find("3duToonGenBase")<>-1: #check if the correct figure is selected SyntaxError: invalid syntax"
RedPhantom ( ) posted Sat, 18 November 2023 at 8:41 AM
Site Admin
It looks like it's trying to call a Python script called Base_Character.py Poser 13 uses Python 3 but older content uses older versions. It is likely an older version that isn't fully compatible with Poser 13.
Digimon ( ) posted Sat, 18 November 2023 at 8:47 AM
RedPhantom posted at 8:41 AM Sat, 18 November 2023 - #4477889
Thank you! I will look into what I can do... if I have to use an older Poser, I have Poser 11, then I will.
Digimon ( ) posted Sat, 18 November 2023 at 9:03 AM
Maybe I have to move the python script into the proper folder?
hborre ( ) posted Sat, 18 November 2023 at 10:19 AM
As with all DAZ content products you need the DAZ Install Manager (DIM) application to install files/folders into both DAZStudio and Poser properly.  DIM has a little learning curve to make it behave appropriately and manual installation is tricky.  From what I see on the DAZ webpage, 3D Universal Toon Generation Base content was created for Poser 7 although I assume it would work through Poser 11.  I agree with RedPhantom that if you are attempting to use the Python Script in Poser 13, it will not work due to the update in the Python version.  Even moving it into the proper folder will not work at all.  Use P11 to install the characters, and perform whatever morphs and clothing you want to do.  Resave them back into the Poser Library and reload them in P13.
Digimon ( ) posted Sat, 18 November 2023 at 10:32 AM
hborre posted at 10:19 AM Sat, 18 November 2023 - #4477893
Thank you both!!! Great helpful information!!
NikKelly ( ) posted Sun, 19 November 2023 at 10:17 AM
Animation or file ??
My recent 're-packaged retro' budget acquisitions from Daz often set folder / file security attributes which I must clear to wrangle the down-load into usable form.
Note: I manually install everything into individual folders in a sprawling archive, whose folders I then link in/out as Poser external libraries. I only use DS to export props, scenes etc that 'DSF Tools' cannot...
Digimon ( ) posted Mon, 20 November 2023 at 6:56 AM
NikKelly posted at 10:17 AM Sun, 19 November 2023 - #4477927
Files.
I used the DAZ3DIM to install the packages, then take the individual runtime folders and redistribute them in the Poser 11 folder structure. As stated, this works for most of the other ones I installed. I believe hborre is correct, that error seems to be a python error.
