Fri, Nov 8, 8:30 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Starting the Mac OS finder with python
Bastep ( ) posted Fri, 13 October 2023 at 4:37 PM · edited Fri, 08 November 2024 at 4:51 PM
I am currently writing a tool to change the textures of figures and props at once. I start the Windows Explorer at a certain place. Depending on the operating system, the Mac OS Finder should also be able to start at this point. But I don't know anything about the Mac OS, nor do I have access to a Mac computer.
Can someone help me?
With kind regards
The code for the Windows Explorer in shortened form
import subprocess
import platform
command = 'explorer /select,"{}"'.format(self.__File)
    if platform.system() == 'Windows':
        subprocess.Popen(command)
an0malaus ( ) posted Sat, 25 November 2023 at 7:45 PM
Uh. I encountered this a couple of years ago and found a solution for macOS. I will search and post shortly (I hope).
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
an0malaus ( ) posted Sat, 25 November 2023 at 8:01 PM
OK. Found it. I remembered working with Andy (structure) on this prior to his tragic passing.
if sys.platform == "win32":
os.startfile( helpFile )
else:
subprocess.call( [ "open", helpFile ] )
The OS test you have is fine, so that can stay.
The next question becomes "Do you care about blocking?"
I.e. the "open" call will basically just tell macOS Finder to open the file with whatever it normally would.
If you need Poser Python to wait for that app (whichever one opens the file) to quit, then a "-W" parameter after the "open" should work.
It all gets quite a bit harder if you need to test for the file being closed, rather than the app quitting.
Hope this helps. :-D
My ShareCG Stuff
Bastep ( ) posted Mon, 27 November 2023 at 6:59 AM
an0malaus posted at 8:01 PM Sat, 25 November 2023 - #4478166
else:
Thanks for the effort. I will integrate this into my Python code and then hope that it works as I imagine.
Greetings and have a nice Monday
