Sun, Jan 5, 4:50 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 04 2:41 pm)
Subject: Why isn't my bump map working in Poser 2014?
Romeo4755 ( ) posted Thu, 21 December 2023 at 2:04 PM · edited Fri, 03 January 2025 at 3:57 AM
I tried various bump maps - black , grey, white lines, black and white background, but the rendered result is always the same and is no different from the one without a bump map. What am I doing wrong& Thank you for listening to my lament.
bump maps:
hborre ( ) posted Thu, 21 December 2023 at 4:13 PM
What is your unit of measure set to in Poser?  Is your bump map also set to a gamma setting of 1?
Romeo4755 ( ) posted Fri, 22 December 2023 at 4:47 AM · edited Fri, 22 December 2023 at 4:47 AM
hborre posted at 4:13 PM Thu, 21 December 2023 - #4479435
I don't know about measure units, I just set Marvelous D for @Poser 8ft@.
As for gamma I did some experiments, thank you for the idea
SIDE 1 of the beetle
Preview:
rendered with no bump, just diffuse, nothing else (how come I get some relief?):
Now I take this bump map (the lines are grey and blurry)
rendered with alpha from render settings:
rendered with alpha 1
now I take this bump map (dark lines, sharp)
rendered with alpha to render settings
alpha 1
As you can see they very much the same. I was trying to make the furrows deeper but no luck.
Romeo4755 ( ) posted Fri, 22 December 2023 at 4:54 AM · edited Fri, 22 December 2023 at 4:54 AM
SIDE 2 (the belly of the beetle) - the same light, I turned the beetle, not the camers
preview
greyish blurry bump
alpha 1 (in fact this is without indirect light, but with and without IL they are roughly the same)
bump map 2 (dark sharp lines)
alpha from render
alpha 1
shvrdavid ( ) posted Sat, 23 December 2023 at 2:53 PM · edited Sat, 23 December 2023 at 2:55 PM
To make the lines appear deeper you will need to use the displacement channel. Bump is for the illusion of depth based on lighting, but it doesn't actually give any real depth. Plug the bump map you made into the displacement channel and try it. Keep in mind that you have to turn on use displacement in the FireFly render settings for displacement to actually work.
NikKelly ( ) posted Mon, 08 January 2024 at 4:48 PM
Did P_2014 have that object parameter to limit displacement ? I was trying to 'displace' a ground-sheet to make low-poly 'grass lawn', could not get it to 'grow'. Changing the displacement limit made a field of 'Elephant Grass'...
hborre ( ) posted Mon, 08 January 2024 at 5:31 PM
The best way to 'grow' grass is using the Hair Room.
RedPhantom ( ) posted Mon, 08 January 2024 at 7:58 PM
Site Admin
https://www.renderosity.com/forums/threads/2633877 This has samples of both displacement grass and hair grass. They were done with an older version, but I think they should still work
